* aclocal/gcc-sanity.m4: New.
* configure.ac: Add RTEMS_CHECK_GCC_SANITY.
* configure.ac: Remove -fasm.
* configure.ac: Remove UNIX AM_CONDITIONAL.
* configure.ac: Remove RTEMS_UNIX, RTEMS_UNIXLIB.
* configure.ac, score/src/threadqenqueuepriority.c: Add
RTEMS_DO_NOT_UNROLL_THREADQ_ENQUEUE_PRIORITY to give user ability to
disable the loop in _Thread_queue_Enqueue_priority from being
unrolled. This reduces code size and makes coverage analysis easier.
* configure.ac: Disable LIBSHELL for unix targets.
* configure.ac: Require <errno.h>. Cleanup comments.
Remove check for <sys/errno.h>.
* configure.ac: Require stdint.h.
* configure.ac: Check for functions in newlib.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add
Lattice Mico32 support.
* configure.ac: Add m32r.
* libcsupport/src/newlibc_exit.c: For some odd reason, the fini
symbol for the m32r in C needs an extra leading _.
* configure.ac: Revert trash committed. Shell builds with m32c now.
* configure.ac, score/cpu/Makefile.am: Initial addition of M32C port.
This is still a work in process but most tests do run on simulator.
* configure.ac: Add generated Doxyfile which can process entire set of
preinstalled .h files.
* Doxyfile.in: New file.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* configure.ac: Abort if stdbool.h is not c99 compliant.
Cleanup mal-formated RTEMS_CPUOPTs.
* configure.ac, libfs/Makefile.am: Add nfsclient to cpukit. Although
the use of RPC/XDR could be an issue, the code does build multilib
across all targets. There are a few remaining warnings to deal with.
* libfs/src/nfsclient/.cvsignore, libfs/src/nfsclient/ChangeLog.slac,
libfs/src/nfsclient/LICENSE, libfs/src/nfsclient/Makefile.am,
libfs/src/nfsclient/README, libfs/src/nfsclient/preinstall.am,
libfs/src/nfsclient/rfc1094.txt,
libfs/src/nfsclient/proto/mount_prot.h,
libfs/src/nfsclient/proto/mount_prot.x,
libfs/src/nfsclient/proto/mount_prot_xdr.c,
libfs/src/nfsclient/proto/nfs_prot.h,
libfs/src/nfsclient/proto/nfs_prot.x,
libfs/src/nfsclient/proto/nfs_prot_xdr.c,
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/librtemsNfs.h, libfs/src/nfsclient/src/nfs.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c, libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.h,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c: New files.
* configure.ac: Fix typo in the strict order mutex CPU OPTs test.
* libmisc/shell/shell.c: Handle '#' comment characters correctly.
* libblock/include/rtems/flashdisk.h: Add docmentation about the
control fields. Add more control fields to handle the flash when
full.
* libblock/src/flashdisk.c: Fix the descriptor erase test so it
detects a descriptor is erased. Add support for unavailable blocks
the user can configure. Print the used list as a diag. Fix the bug
when a page is detected as failed and present on more than one
queue. Add a count to the queues so queue length can be used to
manage compaction.
* configure.ac: fixed bug that always enabled strict order
mutexes.
* score/inline/rtems/score/coremutex.inl: Fixed coding standard.
* score/src/coremutex.c: Add the holder's thread to the lock_mutex
list if the mutex is initialised locked.
* libnetworking/rtems/rtems_glue.c: Changed semaphore error
message to show the error is an rtems-net error.
* libmisc/monitor/mon-network.c: Removed warnings.
* telnetd/icmds.c: Changed shell_* to rtems_shell_*.
* score/Makefile.am: Fixed typo that stopped 'make tags' working.
* libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c,
libmisc/shell/extern-cp.h, libmisc/shell/fts.c,
libmisc/shell/fts.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c, libmisc/shell/verr.c,
libmisc/shell/verrx.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: New. Ported from BSD.
* libmisc/shell/shellconfig.h: Add the cp command.
* libmisc/Makefile.am: Add the new files to the shell.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting
support.
* libblock/src/flashdisk.c: Fixed disk drive count size setting
bug.
* configure.ac, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl: Add the ability to disable
inlining coremutex seize. This reduces the code size and also
improves the process of coverage analysis.
* score/src/coremutexseizeintr.c: New file.
score/inline/rtems/score/coremutex.inl,
score/src/coremutexsurrender.c, score/src/threadinitialize.c: Add
support for proper stacking of priority inheritance on mutexes as
well as enforce proper order of release.
* configure.ac: Revert Joel's 2007-06-13 NDEBUG patch.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* configure.ac, score/inline/rtems/score/thread.inl,
score/src/threaddispatch.c: Add ability for user to disable inlining
of _Thread_Enable_dispatch. This can save code space but more
importantly it means the binary generated does not have code inlined
that is difficult to test and very seldom executed.
* configure.ac: Add ARM/Thumb Makefile.
* configure.ac: Add NDEBUG as a command line compilation option.
* configure.ac, Makefile.am: Add libmd.
* configure.ac: Remove "pad" from CPU_CONTEXT.
* ChangeLog, configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c,
rtems/src/ratemonresetall.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/thread.h,
score/include/rtems/score/timespec.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c,
score/src/timespecdivide.c: Add nanoseconds granularity to the rate
monotonic period statistics and CPU usage statistics. This capability
is enabled by default although may be conditionally disabled by the
user. It could be too much overhead on small targets but it does not
appear to be bad in early testing. Its impact on code size has not
been evaluated either. It is possible that both forms of statistics
gathering could be disabled with further tweaking of the conditional
compilation.
* score/src/timespecdividebyinteger.c: New file.
* configure.ac: Check for working PRIxPTR.
* configure.ac: Redefine LIBPOSIX to !UNIX.
