Close #3250.
Close #4081.
Close #4120.
Due to an unmaintained toolchain (internal errors in GCC, no FSF GDB
integration) the Epiphany architecture was obsoleted in RTEMS 5.1.
Update #3941.
Closes #3839
Support for targets compiled with -fno-pic and -mno-relax
Generate Doxygen output in doc and ignore this directory in Git. Add
RTEMS logo. The Doxygen documentation is now built using the source
tree. Just invoke "doxygen" in the top-level source directory.
The Doxyfile works also with at least Doxygen 1.8.13 and Doxygen 1.8.14.
Update #3705.
Update #3254.
Update #3599.
The results of these checks are unused, covered by other checks or check
obvious things.
Update #3409.
Declarations provided by Newlib since 2002.
Update #3409.
This function is provided by Newlib since 2000.
Update #3409.
Declaration provided by Newlib since 2014.
Update #3409.
Update #3409.
Update #3409.
These functions are provided by Newlib since 2000.
Update #3409.
These functions are provided by Newlib since 2002.
Update #3409.
Avoid a long argument list while creating the librtemscpu.a library
archive.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Update #3491.
Current state:
- Basic context initialization and switching code.
- Stubbed console (empty functions).
- Mostly functional linker script (may need tweaks if we ever want to move
away from the large code model (see: CPU_CFLAGS).
- Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for
UEFI-awareness.
In short, the current state with this commit lets us boot, go through the system
initialization functions, and then call user application's Init task too.
Updates #2898.
Update #3342.
Update #3343.
Install the network headers only if --enable-networking is specified.
Update #3254.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
