* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 1 | -1991/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | confstr() support for RTEMS | Eshan dhawan | 2021-08-18 | 1 | -0/+9 |
| | | | | | | | | Closes #3373 confstr() style update Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com> | ||||
* | Test suite for FTW.H methods | Eshan dhawan | 2021-03-11 | 1 | -0/+26 |
* | psxintrcritical01: Use T_interrupt_test() | Sebastian Huber | 2020-07-23 | 1 | -2/+1 |
* | sptests: Avoid include path magic | Sebastian Huber | 2019-11-12 | 1 | -6/+4 |
| | | | | Update #3818. | ||||
* | tests: Simplify fatal error test support | Sebastian Huber | 2019-11-12 | 1 | -2/+2 |
| | | | | | | Move system.h to shared init.c. Update #3818. | ||||
* | psxtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 1 | -5/+3 |
* | Correct initial POSIX signals mask | Joel Sherrill | 2019-09-24 | 1 | -0/+22 |
| | | | | | | | | | | | | + Modify POSIX thread create extension to ensure expected initial signal mask is provided to system threads, initial tasks and threads, and inheritied by tasks and threads. + Adds psxsignal07 to verify functionality when using a POSIX Initialization thread and POSIX threads. + Adds psxsignal08 to verify functionality when using a Classic API Initialization task and Classic API tasks. Closes #3794. | ||||
* | Add psxfenv01 test to psxtests | Vaibhav Gupta | 2019-09-10 | 1 | -0/+12 |
| | | | | | | Note that this test requires a functional fenv implementation. Some targets have multilib variants where the fenv implementation is not 100% passing. | ||||
* | psxtests: Add ndbm test suite | Vaibhav Gupta | 2019-07-30 | 1 | -0/+11 |
| | | | | | | | | | Joel Sherrill <joel@rtems.org> modified the patch to add autoconf logic to avoid building this new test unless the tool chain include <ndbm.h>. The ensures that git bisect continues to work and that the addition of this test does not immediately force the entire community to update their tools. | ||||
* | psxtests: Add psxinttypes01 for <inttypes.h> methods | Vaibhav Gupta | 2019-06-19 | 1 | -0/+7 |
* | Makefile.am: Add psxhdrs/termios files to build | Joel Sherrill | 2019-05-07 | 1 | -12/+12 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for termios.h | Jacob Shin | 2019-05-07 | 1 | -0/+11 |
* | build: Do not install test programs | Sebastian Huber | 2019-01-30 | 1 | -3/+1 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for errno.h | Jacob Shin | 2019-01-08 | 1 | -0/+1 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h (GCI 2018) | Jacob Shin | 2018-12-13 | 1 | -0/+4 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h (GCI 2018) | Jacob Shin | 2018-12-13 | 1 | -1/+7 |
| | | | | The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste. | ||||
* | psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018) | ABR290B | 2018-12-13 | 1 | -0/+4 |
* | POSIX Signature Compliance Test for utmpx.h (GCI2018) | ABR290B | 2018-12-13 | 1 | -0/+6 |
* | POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018) | ABR290B | 2018-12-13 | 1 | -0/+2 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h | Jacob Shin | 2018-12-12 | 1 | -0/+4 |
* | psxhdrs: POSIX API Signature Compliance Test for setjmp.h (GCI2018) | ABR290B | 2018-12-11 | 1 | -1/+5 |
* | psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h (GCI 2018) | Marçal Comajoan Cara | 2018-12-11 | 1 | -0/+1 |
| | | | | | | | poll.h implements poll() which is not supported by RTEMS according to the RTEMS POSIX 1003.1 Compliance Guide. See #3657. This work was part of GCI 2018. | ||||
* | psxhdrs: Add POSIX Compliance Tests for wordexp.h (GCI 2018) | Pritish Jain | 2018-12-11 | 1 | -0/+2 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for pwd.h (GCI 2018) | Himanshu40 | 2018-12-10 | 1 | -0/+7 |
* | psxtests/Makefile.am: Add fcntl methods missed in previous commit | Joel Sherrill | 2018-12-10 | 1 | -0/+6 |
* | psxtests/Makefile.am: Correct spacing | Joel Sherrill | 2018-12-10 | 1 | -39/+39 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/resource.h (GCI 2018) | Jacob Shin | 2018-12-10 | 1 | -1/+6 |
* | psxhdrs: Implement POSIX API Signature Compliance Tests for sys/times.h (GCI ↵ | Marçal Comajoan Cara | 2018-12-09 | 1 | -1/+2 |
| | | | | 2018) | ||||
* | psxhdrs: Add POSIX Conformance Test for sys/ipc.h (GCI 2018) | Shashvat Jain | 2018-12-09 | 1 | -1/+1 |
| | | | | | | | Test for this file has been added but are disabled due to the absence of header file sys/ipc.h. see Ticket #3650 | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for sys/stat.h (GCI 2018) | Jacob Shin | 2018-12-09 | 1 | -6/+22 |
* | psxhdrs: Added POSIX API Signature Compliance Tests for threads.h (GCI 2018) | Himanshu40 | 2018-12-09 | 1 | -0/+25 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for stdlib.h (GCI 2018) | Jacob Shin | 2018-12-09 | 1 | -2/+68 |
* | psxhdrs: POSIX Signature Test for syslog.h (GCI2018) | ABR290B | 2018-12-08 | 1 | -0/+4 |
* | psxhdrs: added POSIX API Signature Compliance Tests for libgen.h (GCI 2018) | Himanshu40 | 2018-12-08 | 1 | -1/+3 |
* | psxhdrs: Added POSIX Compliance Test for wchar.h (GCI 2018) | zehata | 2018-12-08 | 1 | -1/+83 |
* | Implement POSIX API Signature Compliance Tests for stddef.h (GCI 2018) | Marçal Comajoan Cara | 2018-12-08 | 1 | -0/+1 |
* | POSIX Signature Test for arpa/inet.h (GCI2018) | ABR290B | 2018-12-08 | 1 | -1/+5 |
* | psxhdrs: POSIX API Signature Compliance Tests for netdb.h (GCI 2018) | Himanshu40 | 2018-12-07 | 1 | -1/+24 |
* | Implement POSIX API Signature Compliance Tests for uchar.h | Marçal Comajoan Cara | 2018-12-07 | 1 | -0/+4 |
| | | | | | | | This header file is C11 and not currently supported by RTEMS. See #3643. This work was part of GCI 2018. | ||||
* | psxtests/Makefile.am: Fix ticket number for ucontext.h | Joel Sherrill | 2018-12-06 | 1 | -4/+4 |
* | psxhdrs: Add POSIX API Signature Compliance Tests for ucontext.h (GCI 2018) | Jacob Shin | 2018-12-06 | 1 | -1/+5 |
* | Implement POSIX API Signature Compliance Tests for inttypes.h | Marçal Comajoan Cara | 2018-12-06 | 1 | -1/+8 |
| | | | | This work was part of GCI 2018 | ||||
* | psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018) | Shashvat Jain | 2018-12-06 | 1 | -2/+1 |
* | psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018) | Shashvat Jain | 2018-12-06 | 1 | -1/+3 |
| | | | | | | | Includes test fmtmsg which has been disabled due to the absence of header file fmtmsg.h . Updates #3639 | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for string.h (GCI 2018) | Himanshu40 | 2018-12-06 | 1 | -0/+34 |
* | Added POSIX Compliance Test for <ctype.h> (GCI 2018) | zehata | 2018-12-06 | 1 | -0/+31 |
* | psxhdrs: Add POSIX Conformance Tests for math.h (GCI 2018) | Shashvat Jain | 2018-12-06 | 1 | -0/+192 |
| | | | | | | | | | Includes API tests for y0l, y1l, and ynl which are in glibc but not in POSIX or newlib. They are disabled until further investigation as to compatibility requirements are determined per the referenced ticket. Updates #3638. | ||||
* | POSIX Signature Test for fenv.h (GCI 2018) | ABR290B | 2018-12-06 | 1 | -6/+16 |
| | | | | Updates #2971. | ||||
* | psxhdrs: Add POSIX API Signature Compliance Tests for wctype.h (GCI 2018) | Jacob Shin | 2018-12-06 | 1 | -1/+35 |
