* aclocal/prog-cc.m4: Remove CFLAGS.
* configure.ac: Don't explictly pass CFLAGS_OPTIMIZE_V, CPU_CFLAGS.
Compose CFLAGS. Append CFLAGS to ac_configure_args.
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* configure.ac: Pass --enable-rtems-root to ada-tests/configure.
* configure.ac: Explicitly pass --libdir and --includedir to
testsuites.
* configure.ac: Reflect changes to testsuites.
* aclocal/check-rdbg.m4: Use compilation check on _OLD_EXCEPTIONS
to enable rdbg.
* configure.ac: Add ada/.
* configure.ac: Let enable_rpcgen default to "no".
* configure.ac: Remove HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Remove HAS_WRAPUP_LIBBSP.
* libnetworking/rtems_servers/ftp.c,
libnetworking/rtems_servers/ftp.h,
libnetworking/rtems_servers/Makefile.am:
Remove (relocated to cpukit/ftpd).
* configure.ac, Makefile.am, wrapup/Makefile.am: Reflect having
removed move libnetworking/rtems_servers.
* configure.ac: Remove CFLAGS_DEBUG_V.
Don't AC_SUBST(CFLAGS_OPTIMIZE_V), AC_SUBST(CPU_CFLAGS).
* configure.ac: Pass CFLAGS to testsuites configure.
* aclocal/prog-cxx.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CXXFLAGS. Setup CXXFLAGS from CFLAGS.
* configure.ac: Pass CFLAGS to cpukit configure.
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
* aclocal/env-rtemsbsp.m4:
Comment out CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Add AM_CXXFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE, ASFLAGS.
Cleanup comments.
* configure.ac: Misc. quoting cleanups.
Enable ada-tests iff --enable-ada and --enable-tests.
* configure.ac: Remove check for libbsp/${RTEMS_CPU}.
Add dependency tracking for *.cfgs.
* Makefile.am: Add dependency tracking for *.cfg.
PR 707/make_build
* configure.ac: Add --enable-rpcgen.
PR 700/rtems_misc
* configure.ac, libnetworking/Makefile.am, wrapup/Makefile.am:
Remove libnetworking/rtems_webserver.
* aclocal/env-rtemsbsp.m4: Remove refs to bare BSP.
* aclocal/enable-bare.m4: Remove.
* configure.ac: Remove BARE_CPU_MODEL.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
* configure.ac: Explicitly pass --includedir and --libdir to
cpukit/configure.
* configure.ac: Reflect changes testsuites/configure.ac and
cpukit/configure.ac.
* configure.ac: Reflect changes to testsuites's configuration.
* acinclude.m4: Fix loosing arguments when configuring cpukit and
testsuites (Was exposed with --enable-multilib, only).
Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR.
Add RTEMS_BSP_CONFIG_SUBDIR.
* configure.ac: Reflect changes to acinclude.m4. Reflect new args to
testsuites's configure.
* aclocal/rtems-top.m4: Remove ENDIF hack.
Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am:
Remove.
* librdbg/src/Makefile.am: Merge-in librdbg/src/i386/Makefile.am,
librdbg/src/m68k/Makefile.am, librdbg/src/powerpc/Makefile.am.
* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* configure.ac: Use AS_HELP_STRING(ada).
* configure.ac: Add powerpc's <bsp>/wrapup/Makefile.am detection
hack.
* aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP).
Add AM_CONDITIONAL(HAS_MP).
* wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(Deprecated by autoconf 2.59).
* configure.ac: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* configure.ac: Reflect changes to cpukit.
* configure.ac: Remove libnetworking/wrapup/Makefile.
* wrapup/Makefile.am: Reflect change to libnetworking/*.
Use libnetworking/*/lib*.a instead of libnetapps.a
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake-1.8.2.
Add RTEMS_PROG_CCAS.
Add AM_PROG_CC_C_O.
* automake/compile.am: Remove LINK_LIBS (Unused).
* configure.ac: Reflect changes to RTEMS_CONFIG_SUBDIR.
* configure.ac: Reflect changes to librdbg.
* configure.ac: Remove lib/libbsp/shared/Makefile,
lib/libbsp/shmdr/Makefile.
* configure.ac: Remove libchip/ide/Makefile, libchip/network/Makefile,
libchip/serial/Makefile, libchip/rtc/Makefile.
* configure.ac: Reflect having moved tests to ../../testsuites.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/check-cpu.m4: Remove.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Make presence of tests/ optional.
