This was accidentally removed during a merge conflict by
89fc9345dea5c675f8d93546fa3c723918d3279a.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
This version of mmap comes from early work done
on the RTL code base circa 2012.
Update #2859.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Make _POSIX_Mutex_Default_attributes constant and independent of the
scheduler instance. Use INT_MAX to indicate the default ceiling
priority.
updates #2608.
Enable for all configurations since it pulls in no additional
dependencies. Return value of the scheduler instance of the executing
thread.
dependencies.
Close #2734.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX
thread cancellation to use the thread life states.
Update #2555.
Update #2626.
Make _POSIX_Message_queue_Create_support() static since it is only used
by mq_open().
This is the very simple implementation specified by the Open Group
for implementations with 1:1 kernel thread to user thread mappings.
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_getconcurrency.html
updates #2680.
Yields higher performance on SMP systems.
Close #2625.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Update #2408.
Update #2408.
The RTEMS build of Newlib includes implementations of all exec*()
variants. They rely on the _execve() support method. RTEMS already
had this and it returned ENOSYS. There is no functional change.
closes #2537.
These were not implemented and it does not appear that they were
ever officially part of an approved POSIX standard. They were
likely part of the Draft 8 of POSIX 1003.1b that RTEMS pthreads
were initially based upon.
closes #2531.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
* Makefile.am updated and preinstall.am regenerated.
* mprotect.c had a prototype removed now that we have mman.h
* mmap.c, munmap.c: New stub files.
Enable pthread_once() for all configurations. The pthread_once()
function is one means to initialize POSIX keys. Another use case is the
C++ support.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
This is a useful POSIX thread API helper which is found in
`GNU/Linux and *BSD.
This patch adds the following methods:
+ pthread_get_affinity_np
+ pthread_set_affinity_np
+ pthread_attr_get_affinity_np
+ pthread_attr_set_affinity_np
Change pthread_once from using disabled pre-emption to using a
pthread mutex making it SMP safe. GCC using a posix threading
model uses pthread_once.
The pthread mutex requires at least 1 mutex is configured so
confdefs.h has been updated to account for the internal
mutex.
Move implementation specific parts of key.h and key.inl into new header
file keyimpl.h. The key.h contains now only the application visible
API.
Move implementation specific parts of spinlock.h and spinlock.inl into
new header file spinlockimpl.h. The spinlock.h contains now only the
application visible API.
Move implementation specific parts of timer.h and timer.inl into new
header file timerimpl.h. The timer.h contains now only the application
visible API.
Move implementation specific parts of rwlock.h and rwlock.inl into new
header file rwlockimpl.h. The rwlock.h contains now only the
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
Move implementation specific parts of cond.h and cond.inl into new
header file condimpl.h. The cond.h contains now only the application
visible API.
Move implementation specific parts of barrier.h and barrier.inl into new
header file barrierimpl.h. The barrier.h contains now only the
Move implementation specific parts of mqueue.h and mqueue.inl into new
header file mqueueimpl.h. The mqueue.h contains now only the
Move implementation specific parts of semaphore.h and semaphore.inl into
new header file semaphoreimpl.h. The semaphore.h contains now only the
