* Makefile.am: Reflect addition of include/rtems/bsd/sys/queue.h.
* Makefile.am: Add include/rtems/endian.h.
* Makefile.am: Remove ampolish3.
Remove AM_CONDITIONAL(HAS_ITRON).
* configure.ac, Makefile.am, libfs/Makefile.am:
Introduce AM_CONDITIONAL(LIBDOSFS).
* Makefile.am: Add ampolish3.
* Makefile.am: Remove doxygen support having accidentially slipped
into, though yesterday's patch.
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* backward/rtemspppd.h, backward/rtemsdialer.h: New.
* Makefile.am: Add backward/rtemspppd.h, backward/rtemsdialer.h.
* Makefile.am: Add libnetworking/memory.h
* libnetworking/Makefile.am: Remove memory.h
* Makefile.am, preinstall.am: Added a common irq.h
* include/rtems/irq.h: New file.
* configure.ac: Check for newlib with stdint.h/inttypes.h.
* Makefile.am: Conditionally use external stdint.h/inttypes.h for
newlib.
* configure.ac: Add new header guard to cpuopts.h.
* Makefile.am: Add libfs, libblock, ftpd header install rules.
* libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove
* Makefile.am: Add include/rtems/tar.h.
Merge-in header rules from libmisc/Makefile.am
* libmisc/Makefile.am: Remove header rules.
Remove lib-specific CPPFLAGS.
* configure.ac: Add checks for <tar.h>
* libcsupport/include/rtems/libio.h: Use rtems_id for semaphores.
Use char* for buffer.
* backward/ftpd.h: New.
* Makefile.am: Reflect having added backward/ftpd.h.
PR 756/rtems
* ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from
/c/src/libnetworking/ftpd)
* ftpd/ftd.h: New header guards.
* ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h.
* configure.ac: Add ftpd/Makefile.
* Makefile.am: Add ftpd.
* libcsupport/include/tar.h: New (SUSv3).
* Makefile.am: Integrate newlib-specific headers.
Add libcsupport/include/tar.h.
* libcsupport/Makefile.am: Remove newlib-specific headers.
* acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED.
* backward/motorola/mc68681.h, backward/motorola/mc68230.h,
backward/zilog/z8536.h, backward/zilog/z8036.h,
backward/zilog/z8030.h: New.
* Makefile.am: Reflect having added new files above.
* backward/confdefs.h: New.
* Makefile.am: Add backward/confdefs.h.
Add conditional DEPRECATED.
* configure.ac: Add --enable-deprecated.
* Makefile.am: Add backward/*.h headers.
* itron/Makefile.am: Install itron.h to $(includedir)/rtems.
* libcsupport/Makefile.am: Install RTEMS specific headers to
* libfs/Makefile.am: Install imfs.h and dosfs.h to
PR 561/rtems
* include/rtems/concat.h: New.
* Makefile.am: Add include/rtems/concat.h.
PR/589 rtems
* Makefile.am: Add include/rtems/pci.h.
* Makefile.am: Include automake/compile.am.
* configure.ac: RTEMS_TOP([..],[]).
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* automake/local.am: Remove depend-am.
* automake/subdirs.am: Remove depend-recursive.
* Makefile.am: Remove AUTOMAKE_FILES.
* automake/compile.am: Replace contents with contents of
automake/amcompile.am.
* automake/amcompile.am, automake/lib.am: Remove.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* aclocal/lead-dot.m4: Remove (Use the version in automake-1.8).
* automake/lib.am: Remove $(project_libdir)$(MULTISUBDIR).
* aclocal/env-rtemscpu.m4: Reflect new definition of project_lib.
* Makefile.am: Remove BUILT_SOURCES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* configure.ac: Reflect having removed include/Makefile.am and
librpc/include/Makefile.am.
* configure.ac: Merge-in librpc/configure.ac.
* Makefile.am: Add librpc to SUBDIRS.
Remove @subdirs@.
* configure.ac: Merge-in libcsupport/configure.ac.
* Makefile.am: Add libcsupport to SUBDIRS.
* configure.ac: Merge-in posix/configure.ac.
Merge-in itron/configure.ac.
Misc. cosmetical changes.
* Makefile.am: Add posix, itron to SUBDIRS.
* configure.ac: Merge-in libnetworking/configure.ac.
Remove "rtems-" from RTEMS_VERSION.
Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]).
* Makefile.am: Add libmisc to SUBDIRS.
* configure.ac: Merge-in libmisc/configure.ac.
* configure.ac: Merge-in libfs/configure.ac.
* Makefile.am: Add libfs to SUBDIRS.
* configure.ac: Merge-in libblock/configure.ac.
* Makefile.am: Add libblock to SUBDIRS.
* configure.ac: Merge-in ada/configure.ac.
* Makefile.am: Add ada to SUBDIRS.
