PR 1589/build
* optman/.cvsignore, optman/Makefile.am, optman/preinstall.am,
optman/rtems/no-barrier.c, optman/rtems/no-dpmem.c,
optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c,
optman/rtems/no-part.c, optman/rtems/no-region.c,
optman/rtems/no-rtmon.c, optman/rtems/no-sem.c,
optman/rtems/no-signal.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Removed.
* optman/Makefile.am, optman/preinstall.am: Merge GSOC project code to
add simple device only filesystem (devfs), optionally completely drop
out filesystem, and to clean up disabling newlib reentrancy support.
This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t
now has a 15K code space.
* optman/no-console.c, optman/no-filesystem.c, optman/no-libio.c:
Removed.
* optman/Makefile.am, optman/preinstall.am: Add stubs for file system,
console, and libio. This shrinks the memory requirements but Joel has
not figured out how best to present this to application space.
New files.
* optman/Makefile.am, optman/preinstall.am, optman/rtems/no-dpmem.c,
optman/sapi/no-ext.c: Add optional manager stub for Barrier. Simplify
other optional managers so using them reduces application size
instead of increasing it.
* optman/rtems/no-barrier.c: New file.
* optman/Makefile.am: Add preinstall.am.
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am
support/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* optman/Makefile.am: Set EXEEXT = <empty> (Work around to a bug in
automake).
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* Makefile.am: Use automake compilation rules.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Remove project_libdir.
* Makefile.am: Add tmpinstall dirstamp support.
* Makefile.am: Add dependencies to $(ARCH)/$(dirstamp).
Reformat.
* Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* Makefile.am: Apply install-data-local to install *.rels.
* Makefile.am: Eliminate *_O_FILES.
Don't create $ARCH in %.o: %.c rules.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am.
* sapi/Makefile.am: Removed.
* rtems/Makefile.am: Removed.
* rel.am: Removed.
* configure.ac: Add RTEMS_BSP_CHECK_CACHE.
Reflect changes above.
* Makefile.am: Remove multilib support.
* configure.ac: Ditto.
* sapi/Makefile.am: Ditto.
* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ChangeLog: New.
* configure.ac: New.
* Makefile.am: New.
* rtems/*: Copied from c/src/exec/rtems/optman.
* sapi/*: Copied from c/src/exec/sapi/optman.
