* configure.ac: Use RTEMS_INLINES instead of USE_INLINES.
Elimimate INLINESdir.
* aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS.
* .cvsignore: Add config.h.in.
* configure.ac: Make RTEMS_DEBUG an RTEMS_CPUOPT.
* wrapup/Makefile.am: Reflect having removed libnetworking/wrapup.
* configure.ac: Ditto.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* aclocal/check-posix.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/canonical-host.m4: Remove.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/sysv-ipc.m4: Remove reference to RTEMS_CANONICAL_HOST.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_HOST instead of
AC_CANONICAL_TARGET. Use $host instead of $target.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-cpu.m4: Remove.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Check for sys/cdefs.h.
* aclocal/env-rtems-cpu.m4: Add project_includedir.
Deprecate PROJECT_INCLUDE. Change project_includedir to
$(PROJECT_ROOT)/include for multilibs.
* configure.ac: Reflect having removed include/Makefile.am and
librpc/include/Makefile.am.
* configure.ac: Removed duplicate entry.
* configure.ac: Add libmisc/fsmount/Makefile.
* configure.ac: Merge-in librpc/configure.ac.
* Makefile.am: Add librpc to SUBDIRS.
Remove @subdirs@.
* configure.ac: Merge-in libcsupport/configure.ac.
* Makefile.am: Add libcsupport to SUBDIRS.
* configure.ac: Merge-in posix/configure.ac.
Merge-in itron/configure.ac.
Misc. cosmetical changes.
* Makefile.am: Add posix, itron to SUBDIRS.
* configure.ac: Merge-in libnetworking/configure.ac.
Remove "rtems-" from RTEMS_VERSION.
Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]).
* Makefile.am: Add libmisc to SUBDIRS.
* configure.ac: Merge-in libmisc/configure.ac.
* configure.ac: Merge-in libfs/configure.ac.
* Makefile.am: Add libfs to SUBDIRS.
* configure.ac: Merge-in libblock/configure.ac.
* Makefile.am: Add libblock to SUBDIRS.
* configure.ac: Merge-in ada/configure.ac.
* Makefile.am: Add ada to SUBDIRS.
* configure.ac: Add AC_CONFIG_SUBDIR(libmisc).
* wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead.
* configure.ac: Require autoconf >= 2.54, automake-1.7.2.
* wrapup/Makefile.am: Reflect changes to score/.
* configure.ac: Reflect changes to score/.
* wrapup/Makefile.am: Reflect changes to sapi/.
* configure.ac: Reflect changes to sapi/.
* configure.ac: Add AC_SUBST(INLINEdir).
* wrapup/Makefile.am: Reflect changes to rtems/.
* configure.ac: Reflect changes to rtems/.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* score/include/Makefile.am: Remove cpuopt.h generation.
* configure.ac: Correct package name.
Don't build ada if POSIX is disabled.
Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap.
* aclocal/prog-gnat.m4: New.
* configure.ac: Add ada subdir handling.
* configure.ac: Add missing ',' to librpc activation.
Add AC_MSG_CHECKING/AC_MSG_RESULT.
* aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU.
* configure.ac: Fix bug in librpc activation, having introduced by
yesterday's patch.
* configure.ac: or32 does not currently support librpc.
* configure.ac: Disable LIBRPC for the c4x.
Check for presence of score/cpu/${RTEMS_CPU}/cpu.c.
Let librtemscpu.a depend upon libscorecpu.a.
* configure.ac: RTEMS_TOP(..).
* aclocal/project-root.m4: Remove.
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Remove references to RTEMS_BSP.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
* aclocal/enable-multiprocessing.m4:
Eliminate RTEMS_HAS_MULTIPROCESSING.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* configure.ac: Add libnetworking.
* wrapup/Makefile.am: Ditto.
* configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX).
* wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs.
* configure.ac: Add libcsupport.
* Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove
ITRON_SUBDIRS.
* configure.ac: Rework enable_unixlib handling.
Add RTEMS_MULTILIBS to cpuopts.h.
* include/Makefile.am: Add rtems/fs.h, rtems/userenv.h.
Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
* Makefile.am: Readded reference to wrapup.
* Makefile.am, configure.ac: Remove references to wrapup subdirectory.
* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
* configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
