* Use #ifdefs for 32/64 bit code
* Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
* Move the code to a new shared riscv folder to be shared between riscv32 and riscv64
* Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv
Update #3109
This Newlib check ensures that we have a 64-bit time_t and
self-contained POSIX synchronization objects.
Update #2514.
Update #3111.
Update #3112.
Update #3113.
Update #3114.
Update #3115.
Update #3116.
Update #2833.
This completes the initial creation of rtems/inttypes.h based on all
existing PRIxxx definitions contained in RTEMS Project owned code.
closes #2983.
This is provided by Newlib itself.
Stop the build with a common error message in case the tool chain is
seriously out of date.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
Delete __RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__ as a preparation to
restructure the CORE mutex variants and reduce the branch complexity.
Remove support for strict order mutexes.
Close #2124.
closes #2443.
updates #2452.
updates #2446.
This function is used by Newlib since 2013-07-09 (Git commit
9b51cd8c6b9cdd067d9648a7ab952884019c56a5).
This structure is available in Newlib since 2013-11-29 (Git commit
a534dfd26e765047621acd0eda656ded886e7108).
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
This was obsolete and broken based upon recent time keeping changes.
Thie build option was previously enabled by adding
USE_TICKS_FOR_STATISTICS=1 to the configure command line.
This propagated into the code as preprocessor conditionals
using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
The h8300 gets a linking error for the dl0* tests. This temporarily
disables libdl until that can be investigated.
updates 2284.
There is a GCC ICE when building libdl. This temporarily disables
building libdl until that is resolved.
updates 2283.
There is an issue linking dl0* which has not been resolved.
This issue is being tracked but is not considered a release
blocker. This patch is a workaround which disables libdl
for the v850 until the ticket is resolved.
updates 2260.
for the bfin until the ticket is resolved.
updates 2252.
Close #2219.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
This should have been added.
This is a merge of the RTL project.
This work is based on the old or32 port (that has been
removed back in 2005) authored by Chris Ziomkowski. The patch includes the
basic functions every port should implement like: context switch, exception
handling, OpenRISC ABI and machine definitions and configurations.
