path: root/cpukit/Makefile.am (follow)
* 2005-11-02 straumanatslacdotstanford.eduTill Straumann2005-11-031-0/+4
| | | | | | | | * libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c, libi2c/libi2c.h: New files. * Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a simple API/library for i2c devices and drivers for i2c 2-byte eeproms and a ds1621 temperature sensor; API is documented in libi2c.h
* Add zlib.Ralf Corsepius2005-10-301-0/+2
* Cosmetics.Ralf Corsepius2005-10-271-2/+4
* Add pppd.Ralf Corsepius2005-10-261-0/+1
* 2005-10-26 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-261-0/+2
| | | | | * backward/rtemspppd.h, backward/rtemsdialer.h: New. * Makefile.am: Add backward/rtemspppd.h, backward/rtemsdialer.h.
* Add telnetd.Ralf Corsepius2005-10-251-0/+1
* 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-08-051-0/+2
| | | | | * Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h
* Remove ada.Ralf Corsepius2005-05-231-1/+1
* 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-171-0/+3
| | | | | * Makefile.am, preinstall.am: Added a common irq.h * include/rtems/irq.h: New file.
* Add rtems_bsdnet_HEADERS.Ralf Corsepius2005-05-091-0/+7
* 2005-03-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-03-041-0/+4
| | | | | | * configure.ac: Check for newlib with stdint.h/inttypes.h. * Makefile.am: Conditionally use external stdint.h/inttypes.h for newlib.
* Split preinstallation rules in to separate files (preinstall.am).Ralf Corsepius2005-02-081-305/+13
* 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-081-0/+58
| | | | | | | * configure.ac: Add new header guard to cpuopts.h. * Makefile.am: Add libfs, libblock, ftpd header install rules. * libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove header install rules.
* 2005-02-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-071-1/+120
| | | | | | | | * Makefile.am: Add include/rtems/tar.h. Merge-in header rules from libmisc/Makefile.am * libmisc/Makefile.am: Remove header rules. Remove lib-specific CPPFLAGS. * configure.ac: Add checks for <tar.h>
* 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-041-0/+10
| | | | | | | * libcsupport/include/rtems/libio.h: Use rtems_id for semaphores. Use char* for buffer. * backward/ftpd.h: New. * Makefile.am: Reflect having added backward/ftpd.h.
* 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-041-0/+1
| | | | | | | | | | PR 756/rtems * ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from /c/src/libnetworking/ftpd) * ftpd/ftd.h: New header guards. * ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h. * configure.ac: Add ftpd/Makefile. * Makefile.am: Add ftpd.
* 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-271-0/+66
| | | | | | | * libcsupport/include/tar.h: New (SUSv3). * Makefile.am: Integrate newlib-specific headers. Add libcsupport/include/tar.h. * libcsupport/Makefile.am: Remove newlib-specific headers.
* Add httpd.Ralf Corsepius2004-10-271-0/+1
* 2004-04-12 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-121-0/+38
| | | | | | | | * acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED. * backward/motorola/mc68681.h, backward/motorola/mc68230.h, backward/zilog/z8536.h, backward/zilog/z8036.h, backward/zilog/z8030.h: New. * Makefile.am: Reflect having added new files above.
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-011-4/+14
| | | | | | | | * backward/confdefs.h: New. * Makefile.am: Add backward/confdefs.h. Add conditional DEPRECATED. * configure.ac: Add --enable-deprecated. Add conditional DEPRECATED.
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-011-0/+74
| | | | | | | | | * Makefile.am: Add backward/*.h headers. * itron/Makefile.am: Install itron.h to $(includedir)/rtems. * libcsupport/Makefile.am: Install RTEMS specific headers to $(includedir)/rtems. * libfs/Makefile.am: Install imfs.h and dosfs.h to $(includedir)/rtems.
* 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-291-1/+11
| | | | | | | | | | | | PR 561/rtems * include/rtems/concat.h: New. * Makefile.am: Add include/rtems/concat.h. PR/589 rtems * Makefile.am: Add include/rtems/pci.h. * Makefile.am: Include automake/compile.am. * configure.ac: RTEMS_TOP([..],[]).
* 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-191-1/+3
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+3
| | | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. * automake/local.am: Remove depend-am. * automake/subdirs.am: Remove depend-recursive.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-111-4/+0
| | | | | | | * Makefile.am: Remove AUTOMAKE_FILES. * automake/compile.am: Replace contents with contents of automake/amcompile.am. * automake/amcompile.am, automake/lib.am: Remove.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+1
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+0
| | | | | | | * aclocal/lead-dot.m4: Remove (Use the version in automake-1.8). * automake/lib.am: Remove $(project_libdir)$(MULTISUBDIR). * aclocal/env-rtemscpu.m4: Reflect new definition of project_lib. * Makefile.am: Remove BUILT_SOURCES.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-301-10/+11
| | | | * Makefile.am: Add $(dirstamp) to preinstallation rules.
* 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-16/+24
| | | | | | | | * acinclude.m4: New. * configure.ac: Don't use AUTOHEADER to generate cpuopts.h. Add local autoheader config.h. * aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST. * aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-241-1/+21
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am: Remove. * configure.ac: Reflect having removed include/Makefile.am and librpc/include/Makefile.am.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-2/+1
| | | | | | * configure.ac: Merge-in librpc/configure.ac. * Makefile.am: Add librpc to SUBDIRS. Remove @subdirs@.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-1/+1
| | | | | * configure.ac: Merge-in libcsupport/configure.ac. * Makefile.am: Add libcsupport to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-1/+2
| | | | | | | * configure.ac: Merge-in posix/configure.ac. Merge-in itron/configure.ac. Misc. cosmetical changes. * Makefile.am: Add posix, itron to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-0/+1
| | | | | | | * configure.ac: Merge-in libnetworking/configure.ac. Remove "rtems-" from RTEMS_VERSION. Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]). * Makefile.am: Add libmisc to SUBDIRS.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-1/+4
| | | | | * configure.ac: Merge-in libmisc/configure.ac. * Makefile.am: Add libmisc to SUBDIRS.
| | | | | * configure.ac: Merge-in libfs/configure.ac. * Makefile.am: Add libfs to SUBDIRS.
| | | | | * configure.ac: Merge-in libblock/configure.ac. * Makefile.am: Add libblock to SUBDIRS.
| | | | | * configure.ac: Merge-in ada/configure.ac. * Makefile.am: Add ada to SUBDIRS.
* 2002-07-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-311-1/+1
| | | | | | * aclocal/canonicalize-tools.m4: Remove LD. * automake/lib.am: Remove LD. * Makefile.am: Put preinstall-stamp into CLEANFILES.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-4/+4
| | | | * Include $(top_srcdir)/automake/*.am. Use aclocal/.
* Add AUTOMAKE_FILES.Ralf Corsepius2002-06-151-0/+4
* 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-151-1/+8
| | | | * Makefile.am: Add preinstall-stamp.
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-161-9/+1
| | | | | | | | | * Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove ITRON_SUBDIRS. * configure.ac: Rework enable_unixlib handling. Add RTEMS_MULTILIBS to cpuopts.h. * include/Makefile.am: Add rtems/fs.h, rtems/userenv.h. Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-1/+1
| | | | * Makefile.am: Readded reference to wrapup.
* 2002-01-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-041-1/+1
| | | | * Makefile.am, configure.ac: Remove references to wrapup subdirectory.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-1/+1
| | | | | | | | | | | | | | | | * configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-191-0/+2
| | | | | | | * wrapup/posix/Makefile.am: Add multilib support. * wrapup/itron/Makefile.am: Add multilib support. * wrapup/rtems/Makefile.am: Add multilib support. * Makefile.am: Add multilib support.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-1/+1
| | | | | * configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron. Reflect changes to configuration of rtems, score and sapi subdirs.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-1/+1
