Skip the data cache initialization if we are a secondary processor.
The bug was introduced by e164df5e33608576443b4cd5923a9046358ee773 and
did not show up in tests using Qemu since the data cache behaviour is
not emulated.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Update #3866.
Set the Main Stack Pointer (MSP) to the ISR stack area end just in case
we run using the Process Stack Pointer (PSP). This helps if
applications are started by a boot loader.
Update #3850
Sort alphabetically.
GCC 11 uses DWARF 5 by default.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Update #4202.
Initialize the data and unified cache levels. Invalidate the
instruction cache levels.
Update #4202.
This makes it possible to reuse this loop.
Update #4202.
The start hook arguments are not used by a BSP. Removing them avoids
the need for a stack during the very early system initialization.
Update #4202.
Make sure the branch predictors are invalidated before the first branch
is executed.
Update #4202.
Set the VBAR to the vector table in the start section before
bsp_start_hook_0() is called to earlier handle exceptions in RTEMS.
Set the VBAR to the normal vector table in start.S for the main
processor. Secondary processors set it in bsp_start_hook_0().
Update #4202.
Avoid one level of indirection.
Update #4202.
When moving the headers from the imx BSP to the shared area, the wrong
directory has been selected. This patch fixes that problem.
Update #4180
Remove the target filter for software-generated interrupts since this
feature is not supported by the affinity routing in GICv3.
Update #4202.
Use the targets parameter to determine the targets of the SGI. Change
targets parameter type to 32-bit to ease the parameter passing. GICv3
supports up to 16 targets.
Update #4202.
Update #4202.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
Update #4180
Update #4180
Update #4180
Update #3910.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
In a multi-processor system we must broadcast the TLB maintenance operation to
the Inner Shareable domain to ensure that the other processors update their TLB
caches accordingly.
Close #4068.
Closes #4055
Closes #4056
_CPU_Counter_frequency() can be called by the rtems_counter
initialization before arm_gt_clock_initialize() initializes the value
used in _CPU_Counter_frequency().
Closes #3961.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
At least on GICv1 the interrupts 0 up to including 31 are so called
Peripheral Private Interrupts (PPIs). We have to initialize the
priority of the PPIs on secondary processors.
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
This avoids to pull in via printk() the Termios support which pulls in
the file system support. This fixes a spconfig02 test failure.
Update #3838.
This adds support for the GICv3 interrupt controller along with the
redistributor to control SGIs and PPIs which wasn't present in GICv2
implementations. GICv3 implementations only optionally support
memory-mapped GICC interface interaction and require system register
access be implemented, so the GICC interface is accessed only
through system registers.
Close #3789.
Xen will mask the virtual timer before injecting the interrupt to the
guest.
Xen currently only supports the zImage loader for 32 bit guests on ARM
targets.
The small page MMU support reduces the granularity for memory settings
through the MMU from 1MiB sections to 4KiB small pages.
Enable it by default on the realview_pbx_a9_qemu BSP.
- The TI's CortexA7 MP MPIDR register returns 0
Updates #3760
Closes #3760
This fixes the corruption of r3 by the call to
bsp_start_arm_drop_hyp_mode().
Moving the code makes it easier to review changes in start.S.
Close #3773.
This makes it easier to review changes in start.S.
Update #3773.
There are no known ARMv7-M chips with a dual lockstep mode.
Update #3773.
