* cpu.c, cpu_asm.S, irq.c: Add include of config.h
* cpu.c: Change prototype of IDLE thread to consistently return void *
and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/tic4x/c4xio.h: Sweep to make sure grep for COPYRIGHT passes.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c,
score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c,
cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared
executive initialization.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
Eliminate evil casts.
Use Context_Control_fp* instead of void* for fp_contexts.
* rtems/score/types.h: Use uint_least16_t for
Priority_Bit_map_control;
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
PR rtems/752
* rtems/tic4x/c4xio.h: New (relocated from .).
New header guard.
* c4xio.h: Remove.
* asm.h, rtems/score/c4x.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: New header guards.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/cpu.h: *_swap_u32( uint32_t ).
* rtems/score/types.h: #include <rtems/stdint.h>.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
