* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
PR rtems/752
* rtems/tic4x/c4xio.h: New (relocated from .).
New header guard.
* c4xio.h: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* configure.ac: Remove (Merged into $(top_srcdir)/configure.ac).
* Makefile.am: Don't include multilib.am.
Reflect merging configure.ac into $(top_srcdir)/configure.ac.
* Makefile.am: Install c4xio.h to $(includedir)/rtems/c4x.
* Makefile.am: Install asm.h to $(includedir)/rtems.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
* Makefile.am: Convert to using automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Don't use gmake rules for preinstallation.
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems.c: Remove.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/c4xtypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/Makefile.am: Removed.
* Makefile.am: Add multilib support.
* Makefile.am: Include compile.am, formatting.
* rtems/Makefile.am: formatting.
* rtems/score/Makefile.am: formatting.
