path: root/cpukit/score/cpu/arm/include/rtems/score/arm.h (follow)
* arm: Enable thread ID register for ARMv6Sebastian Huber2023-01-031-1/+2
| | | | Close #4759.
* score/cpu/arm: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* arm: Optimize interrupt handlingSebastian Huber2022-01-171-0/+1
| | | | | Use the SRS (Store Return State) instruction if available. This considerably simplifies the context save and restore.
* arm: Support Armv8 in <rtems/score/arm.h>Sebastian Huber2020-12-101-11/+10
| | | | Update #4202.
* score: Add ARM CPU architecture groupSebastian Huber2019-03-261-1/+1
| | | | Update #3706.
* score: Rename ScoreCPU Doxygen groupSebastian Huber2019-03-261-1/+1
| | | | Update #3706.
* Drop executable permissions on .[ch] filesJoel Sherrill2018-04-301-0/+0
* Add ARM Paravirtualization supportJoel Sherrill2018-03-131-3/+5
| | | | Closes #3305.
* Remove make preinstallChris Johns2018-01-251-0/+94
