Add support to untar XZ compressed files.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
of this patch set.
These were in libcsupport for historical reasons and the placement
no longer made sense.
As part of this move, some of the files were placed under subdirectories
which reflect their installed location.
Thank you git for allowing us to move files. Years of CVS resulted
in files being somewhere they no longer belonged.
The --enable-drvmgr configure option controls the driver manager startup
and not if the driver manager is present or not. Presence of the driver
manager is determined by the architecture (only available on sparc so
far).
Partially revert 47190194866ba83cbfeeb5816bb18ddd9f6e8e50.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
* Makefile.am updated and preinstall.am regenerated.
* mprotect.c had a prototype removed now that we have mman.h
* mmap.c, munmap.c: New stub files.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
This is a merge of the RTL project.
This module makes it easy to redirect and capture stdout, stderr or any
other fd in your application.
The captured data can be sent off board, for example using syslog,
or buffered and displayed in a web page.
This handler is necessary to implement the KQUEUE(2) system calls.
Add <sys/event.h> from FreeBSD 8.4.
This handler is necessary to implement the SELECT(2) and POLL(2) system
calls.
Add <sys/poll.h> from FreeBSD 8.4.
utf8proc is a small library for processing UTF-8 encoded Unicode strings.
Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries.
For the time beeing utf8proc is intended to be used for normalizing and folding UTF-8 strings
for comparison purposes when adding UTF-8 support to the FAT file system.
These two header files were installed from libnetworking even
when networking was disabled. This patch moves them to a
non-networking location and updates uio.h to match the FreeBSD 8.x
source being used for the USB stack and TCP/IP stack upgrade.
- cpukit/include/memory.h
Move from cpukit/libnetworking/memory.h. No changes
- cpukit/include/sys/uio.h
Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version.
- cpukit/include/sys/_iovec.h
New. FreeBSD 8.x file supporting <sys/uio.h>.
- cpukit/Makefile.am
Reflect movement of <memory.h> and <sys/uio.h>.
- cpukit/preinstall.am
Regenerate
- cpukit/libnetworking/nfs/bootp_subr.c
Eliminate use of uio_procp field no longer in FreeBSD structure. This
field was set and never read so eliminating the set has no impact.
for details.
Since the CBS scheduler is inspired by AQuoSA project for Linux, additional API
(qreslib) compliant with Linux has been created.
Sptest for qreslib included.
This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* Makefile.am: Reformat.
* libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files.
* libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes
above.
* include/rtems/bsd/sys/queue.h, include/rtems/bsd/sys/cdefs.h:
Remove.
PR 1762/cpukit
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add generic serial mouse driver and mouse parser. The parser code was
in the pc386 BSP but was generic so cleaned up and placed here.
Serial mouse driver itself is new.
* libmisc/mouse/README, libmisc/mouse/mouse_parser.c,
libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c,
libmisc/mouse/serial_mouse.h: New files.
* include/rtems/btimer.h: New.
* Makefile.am: Add rtems/btimer.h
* libcsupport/include/timerdrv.h: Reflect having split out functions
to rtems/btimer.h.
* Makefile.am, configure.ac: Revert accident commit adding libdbm to
build.
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c:
* posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c,
posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c:
New files.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
PR 1555/cpukit
* Makefile.am, preinstall.am: Install md4.h and md5.h headers.
* include/rtems/tar.h, libcsupport/include/tar.h: Remove.
* configure.ac: Require toolchain to provide tar.h.
* libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h:
Use <tar.h> instead of <rtems/tar.h>.
* Doxygen.in: Update.
Misc. fixes.
* doxy-filter: New (Copy of ../tools/build/doxy-filter).
* Makefile.am: Add doxy-filter.
* Makefile.am, configure.ac: Remove support for shttpd.
* aclocal/enable-shttpd.m4: Remove.
* Makefile.am, configure.ac: Remove support for httpd (GoAhead).
* aclocal/enable-httpd.m4: Remove.
