* shared/include/Makefile.am: Remove.
* shared/src/Makefile.am: Remove.
* shared/Makefile.am: Merge-in Makefile.ams above.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/clock/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/mmu/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/tty_drv/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/include/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/src/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Remove all-local: $(ARCH).
* mpc505/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc505/vectors/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/wrapup/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/console-generic/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/cpm/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/console-generic/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/cpm/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/timer/Makefile.am: Remove all-local: $(ARCH).
* ppc403/clock/Makefile.am: Remove all-local: $(ARCH).
* ppc403/console/Makefile.am: Remove all-local: $(ARCH).
* ppc403/ictrl/Makefile.am: Remove all-local: $(ARCH).
* ppc403/timer/Makefile.am: Remove all-local: $(ARCH).
* ppc403/tty_drv/Makefile.am: Remove all-local: $(ARCH).
* ppc403/vectors/Makefile.am: Remove all-local: $(ARCH).
* shared/include/Makefile.am: Remove all-local: $(ARCH).
* shared/src/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/Makefile.am: Reformat.
* mpc505/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/timer/Makefile.am: Reformat.
* mpc505/vectors/Makefile.am: Reformat.
* mpc6xx/Makefile.am: Reformat.
* mpc6xx/clock/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/mmu/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/timer/Makefile.am: Reformat.
* mpc6xx/wrapup/Makefile.am: Reformat.
* mpc8260/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/clock/Makefile.am: Reformat.
* mpc8260/console-generic/Makefile.am: Reformat.
* mpc8260/cpm/Makefile.am: Reformat.
* mpc8260/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/mmu/Makefile.am: Reformat.
* mpc8260/timer/Makefile.am: Reformat.
* mpc8xx/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/clock/Makefile.am: Reformat.
* mpc8xx/console-generic/Makefile.am: Reformat.
* mpc8xx/cpm/Makefile.am: Reformat.
* mpc8xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/mmu/Makefile.am: Reformat.
* mpc8xx/timer/Makefile.am: Reformat.
* ppc403/Makefile.am: Reformat.
* ppc403/clock/Makefile.am: Reformat.
* ppc403/console/Makefile.am: Reformat.
* ppc403/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/timer/Makefile.am: Reformat.
* ppc403/tty_drv/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/vectors/Makefile.am: Reformat.
* shared/Makefile.am: Reformat.
* shared/include/Makefile.am: Reformat. Use dirstamp for preinstallation.
* shared/src/Makefile.am: Reformat. Use dirstamp for preinstallation.
* wrapup/Makefile.am: Reformat.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/tty_drv/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/include/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/src/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/include/cpu.h: Removed.
* shared/include/Makefile.am: Reflect changes above.
* shared/include/spr.h: Include rtems/powerpc/registers.h instead of
libcpu/cpu.h.
* mpc6xx/clock/c_clock.c: Reflect changes to <rtems/score/cpu.h>.
* mpc6xx/exceptions/asm_utils.S: Ditto.
* mpc6xx/exceptions/raw_exception.c: Ditto.
* mpc6xx/mmu/mmuAsm.S: Ditto.
* mpc6xx/timer/timer.c: Ditto.
* mpc8260/exceptions/asm_utils.S: Ditto.
* mpc8260/exceptions/raw_exception.c: Ditto.
* mpc8xx/exceptions/asm_utils.S: Ditto.
* mpc8xx/exceptions/raw_exception.c: Ditto.
* ppc403/vectors/vectors.S: Include <asm.h> instead of "asm.h".
* shared/include/cpuIdent.h: New.
* shared/include/cpuIdent.c: Reflect having added cpuIdent.h.
* shared/include/cpu.h: Ditto.
* shared/include/Makefile.am: Add cpuIndent.h. Fix EXTRA_DIST.
* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
shared source code.
