The nocache-memory was set as device memory. It's not necessary to be
that strict. Set it to normal non-cacheable non-shareable memory
instead.
The BSP is for a custom i.MXRT1166 based board. At the moment, only the
cortex M7 is supported.
The flash configuration is something very board specific. So move the
file to a board specific location. Beneath that, not all controllers and
configurations need the flash config right at the address 0 of the
flash. For example on the i.MXRT11xx, the config has an offset for some
flash types.
Move the files that are board specific and not specific to the chip
family into a separate folder.
Some parts of the startup code don't apply for all chips. Make that part
chip specific.
Remove the old NXP MCUXpresso SDK and adapt the BSP so that it uses the
new mcux-sdk.
brains GmbH.
Due to API change, the patch also fixes affected BSPs and uses
value provided by MPU CTRL spec option there.
Sponsored-By: Precidata
Updates #3053.
Updates #4625.
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
Update #4180
The EDMA is intialized so make sure the the clock is initialized too.
Update #4180
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
Update #4180
The following files have been imported:
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.h include/fsl_clock_config.h
cp ${SDK}/boards/evkbimxrt1050/project_template/dcd.c start/flash-dcd.c
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.h include/fsl_pin_mux.h
cp ${SDK}/boards/evkbimxrt1050/xip/evkbimxrt1050_flexspi_nor_config.h include/fsl_flexspi_nor_config.h
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052.h include
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052_features.h include
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.c nxp/devices/MIMXRT1052/drivers
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.h include
cp ${SDK}/devices/MIMXRT1052/fsl_device_registers.h include
cp ${SDK}/devices/MIMXRT1052/system_MIMXRT1052.h include/
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h include
Update #4180
