The clock from the ARM timer is derived from the system clock. This clock can
change dynamically e.g. if the system goes into reduced power or in low power
mode. Thus the clock speed adapts to the overall system performance
capabilities. For accurate timing it is recommended to use the system timers.
if BSP_CLOCK_USE_SYSTEMTIMER = 1, use the System Timer, otherwise use the ARM
Timer.
Make the GIC interrupt controller support a subgroup of the generic interrupt
controller support.
In addtion to 1023, the GICC_IAR register may return 1022 as a special value.
Simply check for a valid interrupt vector for the dispatching.
Check the GICC_IAR again after the dispatch to quickly process a next interrupt
without having to go through the interrupt prologue and epiloge.
Replace the BSP_CONSOLE_MINOR BSP option for the Xilinx Zynq BSPs with the new
BSP option ZYNQ_UART_KERNEL_IO_BASE_ADDR. Move the kernel I/O support to a
shared file.
This helps to provide a shared implementation of the kernel I/O support.
Make the initialization and polled functions independent of the Termios
context. This helps to implement the kernel I/O support without a dependency
on the Termios framework.
Move declarations of bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() to <bsp/irq-generic.h>. Canonicalize the
<bsp/irq.h> includes.
Implement bsp_interrupt_get_affinity() and bsp_interrupt_set_affinity() only if
needed (usually RTEMS_SMP).
Provide stub implementations for i386 to fix build errors.
The base addresses and IRQ numbers for UART 0 and 1 were interchanged.
Fix this and set BSP_CONSOLE_MINOR to 0 for this BSP family.
When the CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS definition was added
to AArch64 cache management, it obsoleted the *_1_data/instruction_line
functions. These have been removed since they are no longer referenced.
The AArch64_instruction_cache_inner_shareable_invalidate_all function is
only used when RTEMS_SMP is defined, so only define it in that
circumstance.
The XNandPsu_IsBlockBad() function is insufficient for JFFS2 to
determine whether a block is usable since the function does not report
reserved blocks. JFFS2 is also unable to use the last 4 blocks of each
target attached to the NAND controller since they are reserved for the
Bad Block Table (BBT), but not necessarily marked as such.
Prefer use of XNandPsu_Erase instead of XNandPsu_EraseBlock since the
XNandPsu driver does not expose the primitives necessary to ensure
device readiness after the operation is complete.
Force use of addresses that would be translated by TTBR1 to cause a
translation fault. RTEMS on AArch64 does not use TTBR1 and so attempted
translation of that address range could cause unexpected behavior in the
form of other exception types since TTBR1 is never set.
Ensure that a single locking session is carried over OOB writes
including the OOB read that is sometimes required. This removes the
possibility of another write occurring between the read and write that
would make the write incorrect.
The internal JFFS2 locking does not guarantee that delayed writes will
not step on other reads and writes to the device. This adds locking to
prevent that in the JFFS2 NAND interworking layer.
Swap the zynqmp management console to interrupt-driven operation to
avoid losing data in under-polled situations.
Include <rtems/termiostypes.h> for the Termios device driver support.
Instead of statically defining the device parameters, use the device
information available via the NOR device layer's Flash Configuration
Table.
brains GmbH.
The MMU must be enabled during mapping changes and TLB invalidations.
When this is not the case, TLB updates do not occur correctly in all
cases. This is especially apparent when changing a block entry to a
table entry when remapping small memory ranges in an otherwise
contiguous block.
The existing include path only works from inside the RTEMS build. This
fixes the include path to work both in the RTEMS build and with builds
of external apps since this file gets installed with the BSP.
This adds the glue code necessary to allow JFFS2 to operate on top of
NAND memory hosted by the XNandPsu peripheral/driver.
Interrupts must be disabled during MMU remapping since the majority of
RTEMS including interrupts expects normal memory mapping semantics such
as unaligned accesses.
The whole cache invalidation and flushing functions only ended up
flusing the first N-1 levels of cache due to an off by one error. This
resovles that issue and makes consistent the usage of levels as they
relate to caching.
To ensure data consistency, the cache much be flushed before disabling
the MMU. When the MMU is disabled, all accesses are treated as
non-cachced and thus will bypass the cache.
The address of the nandpsu peripheral is specific to the ZynqMP SoC and
not relevant to other devices that might have one or more instances of
this peripheral.
Add ref-clock-num identifiers to the device tree to ensure that
interfaces use the correct clocks even when some are not used due to
unconnected MII busses. This also adjusts the default ZynqMP PHY
attachment to RGMII-ID which was the default before device trees were
introduced.
Tested on VCK190
Updates #4762
This changes the ZynqMP device tree parsing over to direct libfdt calls
to avoid inclusion of malloc() in the base BSP which currently causes
sp01 to fail due to unexpected use of TLS space.
In the original implementation, level -1 was unused and all levels could
have block-like descriptors (level 2 block descriptors are called page
descriptors). When support for level -1 page tables was added the
constraint on level -1 block descriptors was not honored. This prevents
block descriptors from being mapped at level -1 since the hardware will
not map them properly.
RTEMS may be booted from a dirty environment. Ensure that FPU trap
settings are consistent.
This adds a BSP variant for the ZynqMP BSP family to support the
Innoflight CFC-400X platform. To properly support the CFC-400X, device
trees were added to the ZynqMP platform due to both the optional
management interface as well as alternate physical configuration of the
ethernet interfaces.
This patch adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family. Currently
only LP64 ABI is supported. ILP32 is not supported. RAM starts from 0x80000 in
64Bit kernel mode and MMU from 0x0. All Raspberrypi Pi 4B models and Raspberry
Pi 400 are supported. All the IRQs are similiar to the older Raspberry pi 2 ARM
BSP.
Raspberry Pi 4B has 2 types of UARTs. Only PL011 serial is supported currently.
Mini-UART is not supported. Mini-UART is default UART on the board so it needs
to be disabled by adding "dtoverlay=disable-bt" to the config.txt. No support
for additional 4 PL011-UARTs on the board.
The raspberrypi.h includes many of the address required for the future
development of the RPi 4B BSP. This includes peripherals, ARM Timer, VideoCore
Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
The .data.rel.ro* linker input section pattern accidentally matches with
writeable data those symbol name starts with "ro".
Close #4701.
- Support DDRMC0 region 0 up to 2G in size
- Support DDRMC0 region 1 with DDR memory greater than 2G
up to the DDRMC0 max amount
- Extend the heap with region 1's memory
Closes #4684
Update #4684
This alters the AArch64 page table generation and mapping code and MMU
configuration to use page table level 0 in addition to levels 1, 2, and
3. This allows the mapping of up to 48 bits of memory space and is the
maximum that can be mapped without relying on additional processor
extensions. Mappings are restricted based on the number of physical
address bits that the CPU supports.
This section was added recently and must be mapped to be accessed
without generating an exception.
Sort the .noinit* input sections by name first, then by alignment if two
sections have the same name. This allows the placement of begin/end symbols to
initialize some areas with a special value.
Update #4678.
There were two bugs with MMU page use that were partially hiding each
other. The linker script page table section was 4x the size it needed to
be and the page table allocation routine was allocating pages PTRSIZE
times larger than it needed to. On ILP32, this resulted in incorrect but
functional allocation. On LP64, this resulted in allocation failures
earlier than expected.
- Any page tables need to be flushed if the cache is enabled.
Disabling the cache may only be available in secure mode.
Updates #4664
Always start the executive in Exception Level 1, Non-Secure mode.
If we boot in EL3 Secure with GICv3 then we have to initialize
the distributor and redistributor to set up G1NS interrupts
early in the boot sequence before stepping down from EL3S to EL1NS.
Now there is no need to distinguish between secure and non-secure
world execution after the primary core boots, so get rid of the
AARCH64_IS_NONSECURE configuration option.
