The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
Updates #3053.
Updates #3053.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
This makes the @file documentation independent of the actual file name.
Update #3707.
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Update #2556.
Changed for consistency with other scheduler operations.
Update #2556.
Avoid direct access to thread internal data fields.
Previously, the _Thread_Heir was updated unconditionally in case a new
heir was determined. The _Thread_Dispatch_necessary was only updated in
case the executing thread was preemptible or an internal thread was
unblocked. Change this to update the _Thread_Heir and
_Thread_Dispatch_necessary only in case the currently selected heir
thread is preemptible or a dispatch is forced. Move the schedule
decision into the change priority operation and use the schedule
operation only in rtems_task_mode() in case preemption is enabled or an
ASR dispatch is necessary. This is a behaviour change. Previously, the
RTEMS_NO_PREEMPT also prevented signal delivery in certain cases (not
always). Now, signal delivery is no longer influenced by
RTEMS_NO_PREEMPT. Since the currently selected heir thread is used to
determine if a new heir is chosen, non-preemptible heir threads
currently not executing now prevent a new heir. This may have an
application impact, see change test tm04. Document this change in sp04.
Update #2273.
Return a thread in need for help for the following scheduler operations
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
* score/include/rtems/score/schedulersimple.h,
score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleunblock.c: Correct names as pointed out by
Gedare.
PR 1743/cpu
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple Priority Scheduler as complement to existing Deterministic
Priority Scheduler. This scheduler serves both as an example and as a
lighter weight implementation for smaller systems.
score/src/schedulersimple.c, score/src/schedulersimpleblock.c,
score/src/schedulersimpleextract.c,
score/src/schedulersimpleschedule.c,
score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c:
New files.
