The processor mask implementation uses flsl() from <strings.h> which is
only BSD visible. Move the implementation to a separate header file to
hide it from the API level. This fixes build errors with GCC 14.
The parameters are unused due to API constraints. The functions are
used through function pointers. Alternative implementations may use the
parameters.
Update #4862.
This fixes:
heap.c:268:3: warning: implicit declaration of function 'memset'
Change extend_count to uint32_t from uint16_t to avoid a possible
premature integer overflow when it is later used for multiplication.
Fix rtems_configuration_get_interrupt_stack_size() for some code models.
The _ISR_Stack_size symbol has an arbitrary absolute address and may not
be representable in the code model used by the compiler.
Update #4953.
Store symbols with an arbitrary absolute address such as _TLS_Size,
_TLS_Alignment, _TLS_Data_size, and _TLS_BSS_size in an object to avoid issues
with some code models.
Update #4953.
Update #4844.
Move <rtems/score/gcov.h> to <rtems/test-gcov.h>. These functions do
not belong to an super core service.
These functions do not belong to an super core service.
This function is not a super core service.
Sebastian has agreed to move this out of score. I should have
removed this patch from my tree but accidentally committed it
with another patch.
The only use was in a test.
* _Protected_heap_Get_block_size
* _Protected_heap_Iterate
* _Protected_heap_Resize_block
Closes #4909.
brains GmbH.
Use of this method was likely eliminated during the rework to use
FreeBSD bintime/sbintime.
Close #4905.
There was a cyclic dependency: For RTEMS_STATIC_ANALYSIS we needed
basedefs.h in assert.h. For RTEMS_UNREACHABLE() we needed _Assert() from
assert.h in basedefs.h.
Fix this by introducing _Debug_Unreachable() in basedefs.h.
Add RTEMS_FUNCTION_NAME to basedefs.h and use it in basedefs.h and
assert.h.
Close #4900.
The comment above bintime2timespec() says:
When converting between timestamps on parallel timescales of differing
resolutions it is historical and scientific practice to round down.
However, the delta_nsec value is a time difference and not a timestamp. Also
the rounding errors accumulate in the frequency accumulator, see hardpps().
So, rounding to the closest integer is probably slightly better.
Reviewed by: imp
Pull Request: https://github.com/freebsd/freebsd-src/pull/604
Let A be the current calculation of the frequency accumulator (pps_fcount)
update in pps_event()
scale = (uint64_t)1 << 63;
scale /= captc->tc_frequency;
scale *= 2;
bt.sec = 0;
bt.frac = 0;
bintime_addx(&bt, scale * tcount);
bintime2timespec(&bt, &ts);
hardpps(tsp, ts.tv_nsec + 1000000000 * ts.tv_sec);
and hardpps(..., delta_nsec):
u_nsec = delta_nsec;
if (u_nsec > (NANOSECOND >> 1))
u_nsec -= NANOSECOND;
else if (u_nsec < -(NANOSECOND >> 1))
u_nsec += NANOSECOND;
pps_fcount += u_nsec;
This change introduces a new calculation which is slightly simpler and more
straight forward. Name it B.
Consider the following sample values with a tcount of 2000000100 and a
tc_frequency of 2000000000 (2GHz).
For A, the scale is 9223372036. Then scale * tcount is 18446744994337203600
which is larger than UINT64_MAX (= 18446744073709551615). The result is
920627651984 == 18446744994337203600 % UINT64_MAX. Since all operands are
unsigned the result is well defined through modulo arithmetic. The result of
bintime2timespec(&bt, &ts) is 49. This is equal to the correct result
1000000049 % NANOSECOND.
In hardpps(), both conditional statements are not executed and pps_fcount is
incremented by 49.
For the new calculation B, we have 1000000000 * tcount is 2000000100000000000
which is less than UINT64_MAX. This yields after the division with tc_frequency
the correct result of 1000000050 for delta_nsec.
In hardpps(), the first conditional statement is executed and pps_fcount is
incremented by 50.
This shows that both methods yield roughly the same results. However, method B
is easier to understand and requires fewer conditional statements.
Reviewed by: imp
Reviewed by: imp
Move the pseq increment. This makes it possible to reuse registers earlier.
Reviewed by: imp
Use local variables for the captured timehand and timecounter in pps_event().
This fixes a potential issue in the nsec preparation for hardpps(). Here the
timecounter was accessed through the captured timehand after the generation was
checked.
Make a snapshot of the relevent timehand values early in pps_event(). Check
the timehand generation only once during the capture and event processing. Use
atomic_thread_fence_acq() similar to the other readers.
Reviewed by: imp
This ensures that the timecounter and the tc_get_timecount handler belong
together.
Reviewed by: imp
Sponsored by: Rubicon Communications, LLC ("Netgate")
Since 32c203577a5e by phk in 1999 (Make even more of the PPSAPI
implementations generic), the "nsec" parameter of hardpps() is a time
difference and no longer a time point. Change the name to "delta_nsec"
and adjust the comment.
Remove comment about a clock tick adjustment which is no longer in the code.
Pull Request: https://github.com/freebsd/freebsd-src/pull/640
Reviewed by: imp
The third argument to this function indicates whether the supplied
ticker is fixed or variable, i.e. requiring calibration. Give this
argument a type and name that better conveys this purpose.
Reviewed by: kib, markj
MFC after: 1 week
Sponsored by: The FreeBSD Foundation
Differential Revision: https://reviews.freebsd.org/D35459
(which is used to calculate cputime from cpu ticks) has some imprecision and,
worse, huge timestep (about 20 minutes on 4GHz CPU) near 53.4 days of elapsed
time.
kern_time.c/cputick2timespec() (it is used for clock_gettime() for
querying process or thread consumed cpu time) Uses cputick2usec()
and then needlessly converting usec to nsec, obviously losing
precision even with fixed cputick2usec().
kern_time.c/kern_clock_getres() uses some weird (anyway wrong)
formula for getting cputick resolution.
PR: 262215
Reviewed by: gnn
Differential Revision: https://reviews.freebsd.org/D34558
The goto label was directly after the loop, so we can replace the goto
with a break.
Close #4847.
Add an assert to _Thread_Initialize_scheduler_and_wait_nodes() which may
help a static analyzer. Use a do/while loop since we have at least one
scheduler.
Update #4832.
Several SMP message processing functions returned a value. This value
was always unused.
Close #4822.
Do not use a chained assignment for code clarity.
Close #4818.
Ensure that the IDLE storage allocator did allocate a suffiently large area.
Update #3835.
Update #4524.
By default, allocate the IDLE task storage areas from the RTEMS Workspace.
This avoids having to estimate the thread-local storage size in the default
configuration.
Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to
request a static allocation of the task storage area for IDLE tasks.
Update #3835.
Update #4524.
Add the INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED fatal error in case the
creation of an idle thread fails. This may happen due to a failing create
extension provided by the application.
Update #3835.
Allow the IDLE stack allocator to change the stack size. This can be
used by applications with a very dynamic thread-local storage size to
adjust the thread storage area of the IDLE tasks dynamically.
Update #4524.
For most CPU ports this was already the case. This makes it possible to use
the size as an object alignment using RTEMS_ALIGNED().
Update #4702.
All CPU ports used the same _CPU_Counter_difference() implementation. Remove
this CPU port interface and mandate a monotonically increasing CPU counter.
Close #3456.
The rtems_task_delete() directive is basically just a combined pthread_cancel()
and pthread_join(). In addition, it removes the PTHREAD_DETACHED state. The
exit value returned by pthread_join() of threads cancelled by
rtems_task_delete() should reflect this by getting a PTHREAD_CANCELED value
instead of NULL which could be a normal exit value.
Close #4680.
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
Commit 21275b58a5a69c3c838082ffc8a7a3641f32ea9a ("score: Static
Objects_Information initialization") introduced an off-by-one error in the
maintenance of inactive objects.
Close #4677.
With unlimited objects the object maximum may be larger than the sum of active
and inactive objects.
Update #4677.
Dirty or zero also the part of the .noinit section used by RTEMS.
Close #4678.
Conditional expressions with inline functions are not optimized away if
optimization is disabled. Avoid such expressions to prevent dead
branches.
This function is only used in SMP configurations.
At some point during system initialization, the idle threads are created.
Afterwards, the boot processor basically executes within the context of an idle
thread with thread dispatching disabled. On some architectures, the
thread-local storage area of the associated thread must be set in dedicated
processor registers. Add the new CPU port function to do this:
void _CPU_Use_thread_local_storage( const Context_Control *context )
Close #4672.
Update #4670.
