line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
Update #3059.
Rename struct Scheduler_Control to _Scheduler_Control to allow its use
in standard header files, e.g. <pthread.h>.
Update #3112.
Update #3059.
Update #3059.
Replace the simple processor count with the processor set owned by the
scheduler instance.
Update #3059.
Update #3059.
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Update #2797.
Rename _Scheduler_Assignments into _Scheduler_Initial_assignments to
make it clear that they may not reflect the run-time scheduler
assignment.
Update #2797.
Update #2556.
Remove unused return status.
Update #2556.
Update #2556.
Changed for consistency with other scheduler operations.
Update #2556.
Update #2556.
Update #2556.
This enables to call this scheduler operation for all scheduler nodes
available to a thread.
Update #2556.
Rename the scheduler ask for help stuff since this will be replaced step
by step with a second generation of the scheduler helping protocol.
Keep the old one for now in parallel to reduce the patch set sizes.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
This makes it possible to add scheduler nodes to structures defined in
<rtems/score/thread.h>.
Update #2556.
Split up the potential thread priority change in the scheduler
release/cancel job operation. Protect the rate monotonic period state
with a dedicated SMP lock. This avoids a race condition during
_Rate_monotonic_Timeout() while _Rate_monotonic_Cancel() is called on
another processor.
Do not use a deadline value of zero to indicate a job cancellation. Use
a dedicated scheduler operation for this.
Provide the scheduler node to initialize or destroy to the corresponding
operations. This makes it possible to have more than one scheduler node
per thread.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
Pass the deadline in watchdog ticks to the scheduler.
Update #2173.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
By convention, thread priorities must be integers in RTEMS. Smaller
values represent more important threads.
The priority values are only valid within a scheduler instance. Thus,
the maximum priority value must be defined per scheduler instance. The
first scheduler instance defines PRIORITY_MAXIMUM. This implies that
RTEMS_MAXIMUM_PRIORITY and POSIX_SCHEDULER_MAXIMUM_PRIORITY are only
valid for threads of the first scheduler instance. Further
API/implementation changes are necessary to fix this.
Update #2556.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Delete this variable since it is no longer necessary due to the thread
priority queue implementation change to use RB trees.
The following scheduler operations return a thread in need for help
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
Add a new ask for help scheduler operation. This operation is used by
_Scheduler_Ask_for_help() to help threads in need for help returned by
the operations mentioned above. This operation is also used by
_Scheduler_Thread_change_resource_root() in case the root of a resource
sub-tree changes. A use case is the ownership change of a resource.
In case it is not possible to schedule a thread in need for help, then
the corresponding scheduler node will be placed into the set of ready
scheduler nodes of the scheduler instance. Once a state change from
ready to scheduled happens for this scheduler node it may be used to
schedule the thread in need for help.
Return a thread in need for help for the following scheduler operations
- unblock,
- yield.
Manage the help state of threads with respect to scheduling decisions.
Add a chain node to the scheduler node to decouple the thread and
scheduler nodes. It is now possible to enqueue a thread in a thread
wait queue and use its scheduler node at the same for other threads,
e.g. a resouce owner.
Add and use SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY.
Rename _Scheduler_Update() to _Scheduler_Update_priority(). Add
parameter for the new thread priority to avoid direct usage of
Thread_Control::current_priority in the scheduler operation.
Replace _Scheduler_Allocate() with _Scheduler_Node_initialize(). Remove
the return status and thus the node initialization must be always
successful.
Rename _Scheduler_Free() to _Scheduler_Node_destroy().
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
The thread control block contains fields that point to application
configuration dependent memory areas, like the scheduler information,
the API control blocks, the user extension context table, the RTEMS
notepads and the Newlib re-entrancy support. Account for these areas in
the configuration and avoid extra workspace allocations for these areas.
This helps also to avoid heap fragementation and reduces the per thread
memory due to a reduced heap allocation overhead.
