Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The aim of this file is to encapsulate CPU port implementation details.
This helps to hide implementation details from <rtems.h> which
indirectly includes <rtems/score/cpu.h>.
architectures. SMP atomic port will be later.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
for details.
* Makefile.am: Reformat.
PR 1781/bsps
* bfin/rtems/bf52x.h: This file defines basic MMR for the Blackfin
52x CPU. The MMR have been taken from the ADSP-BF52x Blackfin
Processor Hardware Reference from Analog Devices. Mentioned
Chapters refer to this Documentation.
* Makefile.am: Remove unused file.
* irq.c: Removed.
* Makefile.am, cpu.c, cpu_asm.S, preinstall.am, rtems/score/bfin.h:
Clean up rtems/score/bfin.h removing parts that are not needed by
RTEMS CPUkit to bfin specific .h files.
* rtems/bfin/bf533.h, rtems/bfin/bfin.h: New files.
* .cvsignore, ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c,
preinstall.am, rtems/asm.h, rtems/score/bfin.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: New files.
