PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Remove /*PAGE markers which were
* Makefile.am: Reformat.
* avr/power.h: Revert previous patch.
* cpu.c, avr/interrupt.h, avr/power.h, rtems/score/cpu.h:
PR 1715/cpukit
* rtems/score/cpu.h: Fix typo on _CPU_Context_Restart_self.
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1599/cpukit
* cpu_asm.S: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/asm.h: Fixed header guard.
* rtems/score/cpu.h: Assembler compatibility fixes.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* cpu_asm.S, rtems/score/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* Makefile.am, cpu_asm.S, avr/boot.h, avr/common.h, avr/crc16.h,
avr/delay.h, avr/eeprom.h, avr/fuse.h, avr/interrupt.h, avr/io.h,
avr/io1200.h, avr/io2313.h, avr/io2323.h, avr/io2333.h, avr/io2343.h,
avr/io43u32x.h, avr/io43u35x.h, avr/io4414.h, avr/io4433.h,
avr/io4434.h, avr/io76c711.h, avr/io8515.h, avr/io8534.h,
avr/io8535.h, avr/io86r401.h, avr/io90pwm1.h, avr/io90pwm216.h,
avr/io90pwm2b.h, avr/io90pwm316.h, avr/io90pwm3b.h, avr/io90pwm81.h,
avr/io90pwmx.h, avr/io90scr100.h, avr/ioa6289.h, avr/ioat94k.h,
avr/iocan128.h, avr/iocan32.h, avr/iocan64.h, avr/iocanxx.h,
avr/iom103.h, avr/iom128.h, avr/iom1280.h, avr/iom1281.h,
avr/iom1284p.h, avr/iom128rfa1.h, avr/iom16.h, avr/iom161.h,
avr/iom162.h, avr/iom163.h, avr/iom164.h, avr/iom165.h,
avr/iom165p.h, avr/iom168.h, avr/iom168p.h, avr/iom169.h,
avr/iom169p.h, avr/iom16hva.h, avr/iom16m1.h, avr/iom16u4.h,
avr/iom2560.h, avr/iom2561.h, avr/iom32.h, avr/iom323.h,
avr/iom324.h, avr/iom325.h, avr/iom3250.h, avr/iom328p.h,
avr/iom329.h, avr/iom3290.h, avr/iom32c1.h, avr/iom32hvb.h,
avr/iom32m1.h, avr/iom32u4.h, avr/iom32u6.h, avr/iom406.h,
avr/iom48.h, avr/iom48p.h, avr/iom64.h, avr/iom640.h, avr/iom644.h,
avr/iom645.h, avr/iom6450.h, avr/iom649.h, avr/iom6490.h,
avr/iom64c1.h, avr/iom64m1.h, avr/iom8.h, avr/iom8515.h,
avr/iom8535.h, avr/iom88.h, avr/iom88p.h, avr/iom8hva.h, avr/iomx8.h,
avr/iomxx0_1.h, avr/iomxx4.h, avr/iomxxhva.h, avr/iotn11.h,
avr/iotn12.h, avr/iotn13.h, avr/iotn13a.h, avr/iotn15.h,
avr/iotn167.h, avr/iotn22.h, avr/iotn2313.h, avr/iotn24.h,
avr/iotn25.h, avr/iotn26.h, avr/iotn261.h, avr/iotn28.h,
avr/iotn43u.h, avr/iotn44.h, avr/iotn45.h, avr/iotn461.h,
avr/iotn48.h, avr/iotn84.h, avr/iotn85.h, avr/iotn861.h,
avr/iotn87.h, avr/iotn88.h, avr/iotnx4.h, avr/iotnx5.h,
avr/iotnx61.h, avr/iousb1286.h, avr/iousb1287.h, avr/iousb162.h,
avr/iousb646.h, avr/iousb647.h, avr/iousb82.h, avr/iousbxx2.h,
avr/iousbxx6_7.h, avr/iox128a1.h, avr/iox128a3.h, avr/iox16a4.h,
avr/iox16d4.h, avr/iox256a3.h, avr/iox256a3b.h, avr/iox32a4.h,
avr/iox32d4.h, avr/iox64a1.h, avr/iox64a3.h, avr/lock.h,
avr/parity.h, avr/pgmspace.h, avr/portpins.h, avr/power.h,
avr/sfr_defs.h, avr/signal.h, avr/sleep.h, avr/version.h, avr/wdt.h,
rtems/asm.h, rtems/score/cpu.h: Update to avr .h files from avr-libc
1.6.8. Tinker with code and includes to eliminate warnings. Now
builds multilib.
* avr/iom169pa.h, avr/iom16a.h, avr/iom16hva2.h, avr/iom16hvb.h,
avr/iom16u2.h, avr/iom324pa.h, avr/iom32u2.h, avr/iom644p.h,
avr/iom644pa.h, avr/iom649p.h, avr/iom64hve.h, avr/iom88pa.h,
avr/iom8u2.h, avr/iotn2313a.h, avr/iotn24a.h, avr/iotn261a.h,
avr/iotn4313.h, avr/iotn44a.h, avr/iotn461a.h, avr/iotn861a.h,
avr/iox128d3.h, avr/iox192a3.h, avr/iox192d3.h, avr/iox256d3.h,
avr/iox64d3.h, avr/signature.h: New files.
* cpu.c, cpu_asm.S: Add include of config.h
* rtems/score/avr.h: Add avr6.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Fix bug in
_CPU_Context_Initialize.
* Makefile.am: added AVR specific Header files to score/cpu/avr/avr.
These are from avr-libc 1.6 and assumed to exist by AVR applications.
* preinstall.am: Regenerated.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Context switch now works well
enough to run ticker to completion with the simulator clock idle
task. But if you comment out the printk's in _CPU_Context_Initialize,
it hangs. This remains to be investigated.
* cpu.c, cpu_asm.S: Unsuccessful attempt to fix.
*cpu_asm.S: implemented _CPU_Context_Restore by adding tags to
restore section of context switch.
Fixed bug in _CPU_Context_Switch. The wrong registers were being
used for pointer to running task Context_Control struct.
* cpu_asm.S: Fixed bug in _CPU_Context_Switch. The wrong registers
were being used for pointer to running task Context_Control
struct.
* cpu.c: Implemented _CPU_Context_Initialize as a C function instead
of a macro. It works with limited functionality. Implemented
_CPU_Thread_Idle_body to use sleep instruction.
* Makefile.am: Changed cpu_asm.c -> cpu_asm.S
* cpu_asm.S: renamed from cpu_asm.c and implemented functions is asm
* rtems/asm.h: Appended "macros.inc" to the end of "asm.h"
+ Included "avr/io.h".
+ Added use 16 bit object definition.
+ Modified Context_Control struct to relect the registers
that need to be saved.
+ Implemented _CPU_ISR_Disable, _CPU_ISR_Enable, and _CPU_ISR_Flash.
Added function definitions for _CPU_Context_Initialize and
_CPU_Push.
* rtems/score/cpu.h: Lower number of priorities and do not inline as
much.
* rtems/score/cpu.h: Lower minimum stack size to 512 and CPU alignment
to 4.
* cpu_asm.c: Add stub for setjmp/longjmp. Remove when in newlib.
* rtems/score/cpu.h: AVR stack grows down.
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* cpu.c, cpu_asm.c: Remove warnings -- even if code is just temporary.
* cpu.c, cpu_asm.c: Add debug printk() calls until the BSP/port can
initialize and shutdown completely cleanly. When this works,
implement context switch. Testing on avrtest and simulavr.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* rtems/score/avr.h: Add avr25, avr31, avr35, avr51 to
CPU_NAME cascade.
* rtems/score/cpu.h: Add missing prototypes.h.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/score/avr.h: Sweep to make sure grep for COPYRIGHT passes.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* cpu_asm.c:
Use Context_Control_fp* instead of void* for fp_contexts.
Eliminate evil casts.
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* rtems/score/cpu.h: Remove traces from NO_CPU.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
