* | Remove AVR port | Joel Sherrill | 2016-01-19 | 186 | -208680/+0 |
| | | | | closes #2443. | ||||
* | basedefs.h: Add and use RTEMS_NO_RETURN | Sebastian Huber | 2015-10-26 | 1 | -1/+1 |
* | cpukit: add and use CPU_Uint32ptr type | Gedare Bloom | 2015-03-16 | 1 | -0/+3 |
* | score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITY | Sebastian Huber | 2015-03-05 | 1 | -24/+0 |
* | avr/rtems/score/cpu.h: Fix macros to avoid warnings | Joel Sherrill | 2014-10-09 | 1 | -6/+5 |
* | Let CPU/BSP Fatal handler have access to source | Daniel Hellstrom | 2014-09-10 | 1 | -1/+1 |
| | | | | | | | | | Without the source the error code does not say that much. Let it be up to the CPU/BSP to determine the error code reported on fatal shutdown. This patch does not change the current behaviour, just adds the option to handle the source of the fatal halt. | ||||
* | score: Rename Priority_bit_map_Control | Sebastian Huber | 2014-04-03 | 2 | -2/+2 |
| | | | | Rename Priority_bit_map_Control in Priority_bit_map_Word. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 8 | -8/+8 |
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 2 | -0/+13 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | Add thread-local storage (TLS) support | Sebastian Huber | 2014-02-04 | 1 | -1/+2 |
| | | | | | Tested and implemented on ARM, m68k, PowerPC and SPARC. Other architectures need more work. | ||||
* | score: Simplify <rtems/score/cpuatomic.h> | WeiY | 2013-08-28 | 1 | -30/+6 |
| | | | | Add proper license and copyright. | ||||
* | score/cpu: Add CPU_Per_CPU_control | Sebastian Huber | 2013-08-09 | 1 | -0/+6 |
| | | | | Add CPU port specific per-CPU control. | ||||
* | update-all-architectures-to-new-atomic-implementation | WeiY | 2013-07-17 | 1 | -6/+4 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 1 | -0/+12 |
* | Using the generic atomic ops to implement UP mode atomic for all ↵ | WeiY | 2013-05-01 | 3 | -0/+45 |
| | | | | architectures. SMP atomic port will be later. | ||||
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -363/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | cpukit: Use Consistent Beginning of Doxygen Group Notation | Joel Sherrill | 2013-01-10 | 72 | -138/+135 |
| | | | | | This is the result of a sed script which converts all uses of @{ into a consistent form. | ||||
* | cpukit: Add EOL on files missing EOL at EOF | Joel Sherrill | 2013-01-10 | 93 | -93/+93 |
* | score: Doxygen Clean Up Task #14 | Alex Ivanov | 2013-01-10 | 20 | -30/+290 |
* | score: Doxygen Clean Up Task #12 | Alex Ivanov | 2013-01-10 | 20 | -134/+446 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8110207 | ||||
* | score: Doxygen Clean Up Task #11 | Mathew Kallada | 2013-01-07 | 20 | -830/+1068 |
* | score: Doxygen Clean Up Task #10 | Mathew Kallada | 2013-01-04 | 20 | -801/+1046 |
* | score: Doxygen Clean Up Task #9 | Alex Ivanov | 2013-01-04 | 20 | -1001/+1773 |
* | score: Doxygen Clean Up Task #6 | Mathew Kallada | 2012-12-29 | 18 | -831/+1037 |
* | cpukit avr: Replace dos eol with unix eol. | Jennifer Averett | 2012-12-29 | 1 | -1140/+1140 |
* | score: Doxygen Clean Up Task #8 | Mathew Kallada | 2012-12-29 | 19 | -1017/+961 |
* | score: Doxygen Clean Up Task #7 | Mathew Kallada | 2012-12-28 | 20 | -825/+1086 |
* | score misc: Clean up Doxygen GCI Task #12 | Alex Ivanov | 2012-12-07 | 1 | -40/+6 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7983217 | ||||
* | score: Add CPU_Exception_frame | Sebastian Huber | 2012-11-27 | 3 | -0/+30 |
| | | | | | | | | | | | | | | | | | | | | | Add CPU port type CPU_Exception_frame and function _CPU_Exception_frame_print(). The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh, sparc64, and v850 use an empty default implementation of _CPU_Exception_frame_print(). Add rtems_exception_frame and rtems_exception_frame_print(). Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal() with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc, and sparc for unexpected exceptions. Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the BSP_PRINT_EXCEPTION_CONTEXT define used in the default bsp_fatal_extension(). Add test sptests/spfatal26. | ||||
* | score: PR1607: Add and use CPU_SIZEOF_POINTER | Sebastian Huber | 2012-11-22 | 1 | -0/+2 |
| | | | | | | | | | | | | | | | | | Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an integer literal that can be used by the assembler. This value will be used to calculate offsets of structure members. These offsets will be used in assembler code. The size of a pointer is part of the application binary interface (ABI) and thus independent of the actual programming language. The compiler will provide defines to determine the current ABI. We use these defines to select the appropriate CPU_SIZEOF_POINTER value. Static assertions in the new file "cpukit/score/src/percpuasm.c" will ensure that the value of CPU_SIZEOF_POINTER is consistent with the current compiler settings. Also the offset values used by assembler code are verfied. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 177 | -187/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-09-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-27 | 2 | -0/+7 |
| | | | | | PR 1914/cpukit * rtems/score/cpu.h: Select timestamp implementation. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 4 | -14/+12 |
| | | | | | * cpu.c, cpu_asm.S, rtems/score/cpu.h: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2011-05-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-05-18 | 2 | -39/+156 |
| | | | | * Makefile.am: Reformat. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 2 | -1/+5 |
| | | | | * avr/power.h: Revert previous patch. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 5 | -12/+17 |
| | | | | | * cpu.c, avr/interrupt.h, avr/power.h, rtems/score/cpu.h: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2010-11-06 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-11-06 | 2 | -1/+6 |
| | | | | | PR 1715/cpukit * rtems/score/cpu.h: Fix typo on _CPU_Context_Restart_self. | ||||
* | 2010-10-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-10-21 | 2 | -2/+8 |
| | | | | | | * rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to _CPU_Context_restore() because it does not return. Telling GCC this avoids generation of dead code. | ||||
* | 2010-07-30 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-07-30 | 2 | -1/+7 |
| | | | | | | PR 1599/cpukit * cpu_asm.S: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary to more properly reflect the intent. | ||||
* | 2010-07-29 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-07-29 | 3 | -2/+13 |
| | | | | | | | | | | | PR 1635/cpukit * rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority handling, to isolate the bitmap implementation of priorities in the supercore so that priority management is a little more modular. This change is in anticipation of scheduler implementations that can select how they manage tracking priority levels / finding the highest priority ready task. Note that most of the changes here are simple renaming, to clarify the use of the bitmap-based priority management. | ||||
* | 2010-07-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-27 | 3 | -10/+14 |
| | | | | | * rtems/asm.h: Fixed header guard. * rtems/score/cpu.h: Assembler compatibility fixes. | ||||
* | 2010-07-16 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-16 | 3 | -13/+9 |
| | | | | | * rtems/score/cpu.h: Include <rtems/score/types.h> first. * rtems/score/types.h: Use <rtems/score/basedefs.h> header file. | ||||
* | 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 3 | -23/+10 |
| | | | | | | | | PR 1573/cpukit * cpu_asm.S, rtems/score/cpu.h: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed. | ||||
* | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-10 | 162 | -2171/+52157 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, cpu_asm.S, avr/boot.h, avr/common.h, avr/crc16.h, avr/delay.h, avr/eeprom.h, avr/fuse.h, avr/interrupt.h, avr/io.h, avr/io1200.h, avr/io2313.h, avr/io2323.h, avr/io2333.h, avr/io2343.h, avr/io43u32x.h, avr/io43u35x.h, avr/io4414.h, avr/io4433.h, avr/io4434.h, avr/io76c711.h, avr/io8515.h, avr/io8534.h, avr/io8535.h, avr/io86r401.h, avr/io90pwm1.h, avr/io90pwm216.h, avr/io90pwm2b.h, avr/io90pwm316.h, avr/io90pwm3b.h, avr/io90pwm81.h, avr/io90pwmx.h, avr/io90scr100.h, avr/ioa6289.h, avr/ioat94k.h, avr/iocan128.h, avr/iocan32.h, avr/iocan64.h, avr/iocanxx.h, avr/iom103.h, avr/iom128.h, avr/iom1280.h, avr/iom1281.h, avr/iom1284p.h, avr/iom128rfa1.h, avr/iom16.h, avr/iom161.h, avr/iom162.h, avr/iom163.h, avr/iom164.h, avr/iom165.h, avr/iom165p.h, avr/iom168.h, avr/iom168p.h, avr/iom169.h, avr/iom169p.h, avr/iom16hva.h, avr/iom16m1.h, avr/iom16u4.h, avr/iom2560.h, avr/iom2561.h, avr/iom32.h, avr/iom323.h, avr/iom324.h, avr/iom325.h, avr/iom3250.h, avr/iom328p.h, avr/iom329.h, avr/iom3290.h, avr/iom32c1.h, avr/iom32hvb.h, avr/iom32m1.h, avr/iom32u4.h, avr/iom32u6.h, avr/iom406.h, avr/iom48.h, avr/iom48p.h, avr/iom64.h, avr/iom640.h, avr/iom644.h, avr/iom645.h, avr/iom6450.h, avr/iom649.h, avr/iom6490.h, avr/iom64c1.h, avr/iom64m1.h, avr/iom8.h, avr/iom8515.h, avr/iom8535.h, avr/iom88.h, avr/iom88p.h, avr/iom8hva.h, avr/iomx8.h, avr/iomxx0_1.h, avr/iomxx4.h, avr/iomxxhva.h, avr/iotn11.h, avr/iotn12.h, avr/iotn13.h, avr/iotn13a.h, avr/iotn15.h, avr/iotn167.h, avr/iotn22.h, avr/iotn2313.h, avr/iotn24.h, avr/iotn25.h, avr/iotn26.h, avr/iotn261.h, avr/iotn28.h, avr/iotn43u.h, avr/iotn44.h, avr/iotn45.h, avr/iotn461.h, avr/iotn48.h, avr/iotn84.h, avr/iotn85.h, avr/iotn861.h, avr/iotn87.h, avr/iotn88.h, avr/iotnx4.h, avr/iotnx5.h, avr/iotnx61.h, avr/iousb1286.h, avr/iousb1287.h, avr/iousb162.h, avr/iousb646.h, avr/iousb647.h, avr/iousb82.h, avr/iousbxx2.h, avr/iousbxx6_7.h, avr/iox128a1.h, avr/iox128a3.h, avr/iox16a4.h, avr/iox16d4.h, avr/iox256a3.h, avr/iox256a3b.h, avr/iox32a4.h, avr/iox32d4.h, avr/iox64a1.h, avr/iox64a3.h, avr/lock.h, avr/parity.h, avr/pgmspace.h, avr/portpins.h, avr/power.h, avr/sfr_defs.h, avr/signal.h, avr/sleep.h, avr/version.h, avr/wdt.h, rtems/asm.h, rtems/score/cpu.h: Update to avr .h files from avr-libc 1.6.8. Tinker with code and includes to eliminate warnings. Now builds multilib. * avr/iom169pa.h, avr/iom16a.h, avr/iom16hva2.h, avr/iom16hvb.h, avr/iom16u2.h, avr/iom324pa.h, avr/iom32u2.h, avr/iom644p.h, avr/iom644pa.h, avr/iom649p.h, avr/iom64hve.h, avr/iom88pa.h, avr/iom8u2.h, avr/iotn2313a.h, avr/iotn24a.h, avr/iotn261a.h, avr/iotn4313.h, avr/iotn44a.h, avr/iotn461a.h, avr/iotn861a.h, avr/iox128d3.h, avr/iox192a3.h, avr/iox192d3.h, avr/iox256d3.h, avr/iox64d3.h, avr/signature.h: New files. | ||||
* | 2010-03-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-27 | 3 | -0/+13 |
| | | | | * cpu.c, cpu_asm.S: Add include of config.h | ||||
* | 2009-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-02 | 2 | -0/+8 |
| | | | | * rtems/score/avr.h: Add avr6. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 134 | -595/+595 |
