* | arm: Improve Doxygen file comments | Sebastian Huber | 2023-05-26 | 1 | -2/+5 |
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | score/cpu/arm: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | arm: Fix ARMv7-M interrupt processing | Sebastian Huber | 2017-07-04 | 1 | -11/+17 |
| | | | | | | | | | | | | Right after a "msr basepri_max, %[basepri]" instruction an interrupt service may still take place (observed at least on Cortex-M7). However, pendable service calls that are activated during this interrupt service may be delayed until interrupts are enable again. The _ARMV7M_Pendable_service_call() did not check that a thread dispatch is allowed. Move this test from _ARMV7M_Interrupt_service_leave() to _ARMV7M_Pendable_service_call(). Update #3060. | ||||
* | Include missing <rtems/score/threaddispatch.h> | Sebastian Huber | 2013-07-26 | 1 | -1/+2 |
* | arm: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-01-07 | 1 | -2/+1 |
* | score misc: Clean up Doxygen GCI Task #12 | Alex Ivanov | 2012-12-07 | 1 | -0/+6 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7983217 | ||||
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+44 |
* rtems/score/armv7m.h, armv7m-context-initialize.c, armv7m-context-restore.c, armv7m-context-switch.c, armv7m-exception-handler-get.c, armv7m-exception-handler-set.c, armv7m-exception-priority-get.c, armv7m-exception-priority-set.c, armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c, armv7m-isr-level-get.c, armv7m-isr-level-set.c, armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. * rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S: Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. |
