* | arm: Remove legacy execption support | Sebastian Huber | 2017-03-08 | 1 | -166/+0 |
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | * rtems/score/armv7m.h, armv7m-context-initialize.c, armv7m-context-restore.c, armv7m-context-switch.c, armv7m-exception-handler-get.c, armv7m-exception-handler-set.c, armv7m-exception-priority-get.c, armv7m-exception-priority-set.c, armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c, armv7m-isr-level-get.c, armv7m-isr-level-set.c, armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. * rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S: Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. | ||||
* | add/adapt documentation | Thomas Doerfler | 2010-04-08 | 1 | -1/+3 |
* | 2010-03-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-27 | 1 | -0/+4 |
| | | | | | * arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S, cpu.c, cpu_asm.S: Add include of config.h | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 1 | -1/+1 |
* | * rtems/score/cpu.h: Fix for inline asm in _CPU_Fatal_halt(). | Thomas Doerfler | 2009-09-18 | 1 | -21/+3 |
| | | | | | * rtems/asm.h: Added macro to define ARM functions. * cpu_asm.S, arm_exc_handler_low.S: Use macro from above. | ||||
* | adding lpc24xx BSP parts | Thomas Doerfler | 2009-07-17 | 1 | -0/+176 |
