Casts from uint64_t to void* must go through a uintptr_t cast to avoid
warnings when building with the ILP32 ABI since this is otherwise an
implicit truncation to 32bits for a pointer.
Add _CPU_Get_TLS_thread_pointer() to get the thread pointer which is
used to get the address of thread-local storage objects associated with
a thread.
Update #4920.
Update #3835.
Directly use "static inline" which is available in C99 and later. This brings
the RTEMS implementation closer to standard C.
Close #3935.
At some point during system initialization, the idle threads are created.
Afterwards, the boot processor basically executes within the context of an idle
thread with thread dispatching disabled. On some architectures, the
thread-local storage area of the associated thread must be set in dedicated
processor registers. Add the new CPU port function to do this:
void _CPU_Use_thread_local_storage( const Context_Control *context )
Close #4672.
Add an architecture-specific implementation for
_CPU_Get_current_per_CPU_control() to reduce overhead for getting the
current CPU's Per_CPU_Control structure.
This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
is a proper declaration of a function which does not return. Fix the type of
the error code. If necessary, add the implementation to cpu.c. Implementing
_CPU_Fatal_halt() as a function makes it possible to wrap this function for
example to fully test _Terminate().
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
