* configure.ac: Remove RTEMS_USES_INTTYPES_H. Require inttypes.h.
* include/rtems/stdint.h: Remove "wild guesses", require inttypes.h.
* libcsupport/include/inttypes.h: Cleanup.
* libcsupport/include/stdint.h: Cleanup.
* include/sys/_stdint.h: Various changes.
Add *leastN_t types. Add INTN_{MIN|MAX} macros.
Add doxygen preamble.
* include/sys/_inttypes.h: Add doxygen preamble.
Reflect changes above.
* libcsupport/include/stdint.h: Add doxygen preamble.
* libcsupport/include/inttypes.h: Add doxygen preamble.
* configure.ac: Add doxygen preamble to cpuopts.h.
* configure.ac: Remove -ansi (Cygwin breaks with it).
* libcsupport/include/stdint.h: Use sys/_stdint.h to setup fixed
size types.
* libcsupport/include/sys/_inttypes.h: Add SCN*N macros.
* configure.ac: Remove RTEMS_CPUOPT([RTEMS_MULTILIBS],..).
(Unused).
* configure.ac: Add score/cpu/no_cpu/Makefile.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
* configure.ac: Rework stdint.h/inttypes.h support.
Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H.
Remove NEED_STDINT_H. Remove NEED_INTTYPES_H.
Remove termios-flag detection.
* libcsupport/Makefile.am: Install include/stdint.h and
include/inttypes.h for NEWLIB only.
* libcsupport/include/stdint.h: Rework; Now newlib specific.
* libcsupport/src/termios.c: Make newlib specific.
* include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>.
* aclocal/rtems-cpu-subdirs.m4: Remove (Unused).
* configure.ac: Remove RTEMS_CPU_SUBDIRS([score/cpu]).
Add RTEMS_CHECK_SYSV_UNIX.
Add score/cpu/*/Makefile.
* score/cpu/Makefile.am: Add DIST_SUBDIRS.
* configure.ac: Add AC_CHECK_SIZEOF([CPU_CONTEXT]..).
Add SIZEOF_CPU_CONTEXT to cpuopts.h.
Add RTEMS_PROG_CCAS.
* acinclude.m4: Use unquoted "here" document to propagate $3 to
cpuopts.tmp.
* backward/confdefs.h: New.
* Makefile.am: Add backward/confdefs.h.
Add conditional DEPRECATED.
* configure.ac: Add --enable-deprecated.
PR 561/rtems
* include/rtems/concat.h: New.
* Makefile.am: Add include/rtems/concat.h.
PR/589 rtems
* Makefile.am: Add include/rtems/pci.h.
* Makefile.am: Include automake/compile.am.
* configure.ac: RTEMS_TOP([..],[]).
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* configure.ac: Requires automake >= 1.8.1.
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* automake/amcompile.am: New.
* configure.ac: Add subdir-objects, AM_PROG_CC_C_O.
* configure.ac: Reflect having removed
libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am.
* configure.ac: Reflect changes to libmisc/*.
* configure.ac: Reflect changes to libfs Makefile.ams.
* configure.ac: Use here-documents to generate cpuopts.tmp.
Various fixes and changes to argument processing.
Reflect changes to librpc Makefile.ams.
* acinclude.m4: Use here-documents to generate cpuopts.tmp.
* aclocal/check-itron.m4: Remove HAS_IRON_API.
* aclocal/check-multiprocessing.m4: Remove HAS_MP.
* aclocal/check-posix.m4: Remove HAS_POSIX_API.
* configure.ac: Use RTEMS_INLINES instead of USE_INLINES.
Elimimate INLINESdir.
* aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS.
* .cvsignore: Add config.h.in.
* configure.ac: Make RTEMS_DEBUG an RTEMS_CPUOPT.
* wrapup/Makefile.am: Reflect having removed libnetworking/wrapup.
* configure.ac: Ditto.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* aclocal/check-posix.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/canonical-host.m4: Remove.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/sysv-ipc.m4: Remove reference to RTEMS_CANONICAL_HOST.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_HOST instead of
AC_CANONICAL_TARGET. Use $host instead of $target.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-cpu.m4: Remove.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Check for sys/cdefs.h.
* aclocal/env-rtems-cpu.m4: Add project_includedir.
Deprecate PROJECT_INCLUDE. Change project_includedir to
$(PROJECT_ROOT)/include for multilibs.
* configure.ac: Reflect having removed include/Makefile.am and
librpc/include/Makefile.am.
* configure.ac: Removed duplicate entry.
* configure.ac: Add libmisc/fsmount/Makefile.
* configure.ac: Merge-in librpc/configure.ac.
* Makefile.am: Add librpc to SUBDIRS.
Remove @subdirs@.
* configure.ac: Merge-in libcsupport/configure.ac.
* Makefile.am: Add libcsupport to SUBDIRS.
* configure.ac: Merge-in posix/configure.ac.
Merge-in itron/configure.ac.
Misc. cosmetical changes.
* Makefile.am: Add posix, itron to SUBDIRS.
* configure.ac: Merge-in libnetworking/configure.ac.
Remove "rtems-" from RTEMS_VERSION.
Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]).
* Makefile.am: Add libmisc to SUBDIRS.
* configure.ac: Merge-in libmisc/configure.ac.
* configure.ac: Merge-in libfs/configure.ac.
* Makefile.am: Add libfs to SUBDIRS.
* configure.ac: Merge-in libblock/configure.ac.
* Makefile.am: Add libblock to SUBDIRS.
* configure.ac: Merge-in ada/configure.ac.
* Makefile.am: Add ada to SUBDIRS.
* configure.ac: Add AC_CONFIG_SUBDIR(libmisc).
* wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead.
* configure.ac: Require autoconf >= 2.54, automake-1.7.2.
* wrapup/Makefile.am: Reflect changes to score/.
* configure.ac: Reflect changes to score/.
* wrapup/Makefile.am: Reflect changes to sapi/.
* configure.ac: Reflect changes to sapi/.
