path: root/cpukit/Makefile.am (follow)
* Move printer initialization to separate headerSebastian Huber2016-06-221-0/+1
| | | | | | The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>.
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-0/+1
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* Move various driver interface definition headers file libcsupport/ to include/Joel Sherrill2016-03-301-1/+7
| | | | | | | | | | | These were in libcsupport for historical reasons and the placement no longer made sense. As part of this move, some of the files were placed under subdirectories which reflect their installed location. Thank you git for allowing us to move files. Years of CVS resulted in files being somewhere they no longer belonged.
* drvmgr: Install header files conditionallySebastian Huber2016-01-261-0/+2
| | | | | | | | | The --enable-drvmgr configure option controls the driver manager startup and not if the driver manager is present or not. Presence of the driver manager is determined by the architecture (only available on sparc so far). Partially revert 47190194866ba83cbfeeb5816bb18ddd9f6e8e50.
* drvmgr: Remove dupl bsp_driver_level_hook() declSebastian Huber2016-01-261-2/+0
* libfdt: Initial importSebastian Huber2015-10-161-0/+1
| | | | | | | | | | | | | | Import from: git://git.kernel.org/pub/scm/utils/dtc/dtc.git Commit: 604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e Date: 2015-09-29T09:09:08Z
* libstdthreads: Add C11 threadsSebastian Huber2015-10-141-0/+1
* DRVMGR: only build on SPARC platformDaniel Hellstrom2015-04-171-0/+2
* DRVMGR: added driver manager to cpukit/libdrvmgrDaniel Hellstrom2015-04-171-0/+7
* LIBPCI: added PCI layer to cpukit/libpciDaniel Hellstrom2015-04-171-0/+3
* libmisc/shell: Add the rtrace command for buffered tracing support.Chris Johns2015-03-311-0/+5
| | | | | The rtrace command interfaces to the RTEMS Trace Linker's trace buffering data allowing users to capture and report trace data.
* Move test support from sapi to libmisc/testsupportSebastian Huber2015-03-051-0/+3
* sys/mman.h: New file. Clean up and add supporting stubsJoel Sherrill2014-11-201-0/+1
| | | | | | * Makefile.am updated and preinstall.am regenerated. * mprotect.c had a prototype removed now that we have mman.h * mmap.c, munmap.c: New stub files.
* Add crypt_r(), etc.Sebastian Huber2014-11-201-0/+2
| | | | | Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and crypt_sha512_r().
* Add SHA256 and SHA512 supportSebastian Huber2014-11-201-2/+0
* Add <sys/endian.h>Sebastian Huber2014-11-201-0/+1
* Add RTEMS port of Linux I2C user-space APISebastian Huber2014-11-201-0/+1
* cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns2014-10-311-1/+19
| | | | This is a merge of the RTL project.
* libmisc: Add a stdio redirector helper.Chris Johns2014-09-161-0/+2
| | | | | | | | This module makes it easy to redirect and capture stdout, stderr or any other fd in your application. The captured data can be sent off board, for example using syslog, or buffered and displayed in a web page.
* capture: Add support for variable length records.Jennifer Averett2014-09-051-0/+1
* Filesystem: Add kernel event filter handlerSebastian Huber2013-11-041-0/+1
| | | | | | This handler is necessary to implement the KQUEUE(2) system calls. Add <sys/event.h> from FreeBSD 8.4.
* Filesystem: Add poll() handlerSebastian Huber2013-11-041-0/+1
| | | | | | | This handler is necessary to implement the SELECT(2) and POLL(2) system calls. Add <sys/poll.h> from FreeBSD 8.4.
* JFFS2: Add RTEMS supportSebastian Huber2013-09-191-0/+3
* libmisc: Add utf8proc-v1.1.5Ralf Kirchner2013-06-031-0/+3
| | | | | | | utf8proc is a small library for processing UTF-8 encoded Unicode strings. Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries. For the time beeing utf8proc is intended to be used for normalizing and folding UTF-8 strings for comparison purposes when adding UTF-8 support to the FAT file system.
* Move <memory.h> and <sys/uio.h> to non-networking directoryJoel Sherrill2013-01-231-2/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | These two header files were installed from libnetworking even when networking was disabled. This patch moves them to a non-networking location and updates uio.h to match the FreeBSD 8.x source being used for the USB stack and TCP/IP stack upgrade. - cpukit/include/memory.h Move from cpukit/libnetworking/memory.h. No changes - cpukit/include/sys/uio.h Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version. - cpukit/include/sys/_iovec.h New. FreeBSD 8.x file supporting <sys/uio.h>. - cpukit/Makefile.am Reflect movement of <memory.h> and <sys/uio.h>. - cpukit/preinstall.am Regenerate - cpukit/libnetworking/nfs/bootp_subr.c Eliminate use of uio_procp field no longer in FreeBSD structure. This field was set and never read so eliminating the set has no impact.
* libblock: Add sparse diskRalf Kirchner2012-12-051-0/+1
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* PR1908: consolidate libqos code and fix installed header locationGedare Bloom2012-04-231-1/+3
* PR1908: QoS library for CBS schedulerPetr Benes2012-04-151-0/+1
| | | | | | | Since the CBS scheduler is inspired by AQuoSA project for Linux, additional API (qreslib) compliant with Linux has been created. Sptest for qreslib included.
* Revert "Google C++ Testing Framework 1.6.0."Sebastian Huber2012-01-261-1/+0
| | | | This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* Google C++ Testing Framework 1.6.0.Sebastian Huber2012-01-231-0/+1
* 2011-05-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-05-161-50/+62
| | | | * Makefile.am: Reformat.
* 2011-05-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-131-1/+2
| | | | | | * libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files. * libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes above.
* 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-241-4/+0
| | | | | | * include/rtems/bsd/sys/queue.h, include/rtems/bsd/sys/cdefs.h: Remove. * Makefile.am: Reflect changes above.
* 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-03-141-0/+4
| | | | | | | | | | | PR 1762/cpukit * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add generic serial mouse driver and mouse parser. The parser code was in the pc386 BSP but was generic so cleaned up and placed here. Serial mouse driver itself is new. * libmisc/mouse/README, libmisc/mouse/mouse_parser.c, libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c, libmisc/mouse/serial_mouse.h: New files.
* 2011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-091-0/+1
| | | | | | | * include/rtems/btimer.h: New. * Makefile.am: Add rtems/btimer.h * libcsupport/include/timerdrv.h: Reflect having split out functions to rtems/btimer.h.
* 2010-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-041-1/+0
| | | | | * Makefile.am, configure.ac: Revert accident commit adding libdbm to build.
* 2010-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-041-0/+1
| | | | | | | * Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c: * posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c, posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c: New files.
* 2010-08-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-131-1/+2
| | | | | | | | * libblock/include/rtems/media.h, libblock/src/media-desc.c, libblock/src/media-dev-ident.c, libblock/src/media-path.c, libblock/src/media-server.c, libblock/src/media.c: New files. * Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes above.
* Remove itron.Ralf Corsepius2010-06-171-1/+1
* 2010-06-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-06-141-1/+3
| | | | | PR 1555/cpukit * Makefile.am, preinstall.am: Install md4.h and md5.h headers.
* 2010-06-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-131-1/+1
| | | | | | | * include/rtems/tar.h, libcsupport/include/tar.h: Remove. * configure.ac: Require toolchain to provide tar.h. * libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h: Use <tar.h> instead of <rtems/tar.h>.
* 2010-06-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-111-0/+3
| | | | | | | * Doxygen.in: Update. Misc. fixes. * doxy-filter: New (Copy of ../tools/build/doxy-filter). * Makefile.am: Add doxy-filter.
* 2010-06-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-091-1/+0
| | | | | * Makefile.am, configure.ac: Remove support for shttpd. * aclocal/enable-shttpd.m4: Remove.
| | | | | * Makefile.am, configure.ac: Remove support for httpd (GoAhead). * aclocal/enable-httpd.m4: Remove.
* 2010-02-18 Chris Johns <chrisj@rtems.org>Chris Johns2010-02-181-0/+23
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir-hash.h, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.h, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h, libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: New. * Makefile.am, preinstall.am, libfs/Makefile.am, wrapup/Makefile.am: Updated with the RFS support. * libfs/README: Updated after 10 years. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk-driver.c: Updated to the new error reporting in libblock. * libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing the size in long mode. * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP to the forever behaviour of 4.9 with the ability to call BOOTP and control the process if required.
* 2009-11-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-221-0/+1
| | | | * Makefile.am: Add mghttpd.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-2/+0
| | | | * Makefile.am: Unconditional build libblock.
