* wrapup/Makefile.am: Don't include lib.am.
* automake/compile.am: Use automake compilation rules.
* aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP).
Add AM_CONDITIONAL(HAS_MP).
* wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(Deprecated by autoconf 2.59).
* configure.ac: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Add AM_CONDITIONAL HAS_WRAPUP_LIBBSP.
* wrapup/Makefile.am: Reflect changes to librdbg.
* aclocal/enable-bare.m4: Convert to autoconf-2.59.
* wrapup/Makefile.am: Reflect changes to libchip/*.
* support/Makefile.am: Use automake compilation rules.
* wrapup/Makefile.am: Reflect changes to support/*.
* configure.ac: Remove libnetworking/wrapup/Makefile.
* wrapup/Makefile.am: Reflect change to libnetworking/*.
Use libnetworking/*/lib*.a instead of libnetapps.a
* wrapup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* automake/lib.am: Remove TMPINSTALL_FILES.
* wrapup/Makefile.am: Reflect changes to shmdr.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* wrapup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* acinclude.m4: Rework RTEMS_CONFIG_SUBDIR.
* Makefile.am: Reflect changes to RTEMS_CONFIG_SUBDIR.
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from
* aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir).
* automake/lib.am: Remove project_libdir.
* wrapup/Makefile.am: Reworked.
* support/Makefile.am: Remove all-local: $(ARCH).
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* wrapup/Makefile.am: Remove libmisc.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* wrapup/Makefile.am: Pick up ../libchip/rtc/$(ARCH)/librtcio.a and
../libchip/serial/$(ARCH)/libserialio.a.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(@RTEMS_BSP_FAMILY).
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
Use RTEMS_BSP_FAMILY to detect the bare BSP.
* Makefile.am: Remove setting up bsplibdir.
* Makefile.am: explicitly create $(ARCH) when building $(LIB).
Add bsplib_DATA = $(LIB).
* Makefile.am: Pickup libbsp.a from build directory.
* Makefile.am: Pickup libnetapps.a from build directory.
* Makefile.am: Pickup libmisc.a from build directory.
Remove libxdr.a.
* wrapup/Makefile.am: Remove libxdr.a.
* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
* Makefile.am: Reflect moving libnetworking. Use libnetapps instead.
* configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* Makefile.am: Remove libblock, libfs.
* configure.ac: Special treatment of the bare BSP.
Add RTEMS_BSP_ALIAS. Add HAS_LIBBSP.
* Makefile.am: Append libbsp.a to SRC conditionally.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* Makefile.am: Modified to reflect addition.
* configure.ac: Remove references to POSIX, ITRON, MULTILIB.
* Makefile.ac: Remove librtems, libposix, libitron. Build
librtemsbsp instead of librtemsall.
* configure.ac: Add AM_CONDITIONAL for enable_multilib,
enable_posix, enable_itron.
* Makefile.am: Compute MULTISUBDIR on-the-fly. Conditionally add
libposix and libitron to SRCS. Apply MULTISUBDIR for picking up
librtems, libposix and libitron.
* Makefile.am: Remove subshell from *.a processing in librtemsall.a
rule.
* ChangeLog: New file.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* configure.in: New file.
* .cvsignore: Add aclocal.m4, configure.
* wrapup/Makefile.am: Added libfs.
* wrapup/Makefile.am: Include compile.am.
which is an adaptation of a patch from Ian Lance Taylor plus a few
other changes that should significantly speed up building librtemsall.a.
<corsepiu@faw.uni-ulm.de>.
