Close #3250.
Close #4081.
Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap()
for all unexpected traps. This enables a proper RTEMS fatal error handling
right from the start. Do not rely on the stack and register settings which
caused an unexpected trap. Use the ISR stack of the processor to do the fatal
error handling. Save the full context which caused the trap. Fatal error
handler may use it for error logging.
Unify the _CPU_Exception_frame_print() implementations and move it to cpukit.
Update #4459.
Moves drvmgr_drivers[] from amba.c to a separate file in order
to avoid the dependecy on APBUART/GPTIMER drivers. This has
an effect when user configured not to use timer or uart
in their project.
Update #4267.
Update #3678.
This reduces the link-time dependencies and avoids copy-and-paste.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
This file is BSP-independent.
Update #3285.
The definition of _CPU_Trap_slot_template is BSP-independent. A
potential para-virtualization support may use <rtems/score/paravirt.h>.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is necessary to pick up mandatory flags provided by the build
system.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Update #2355
The GRSPW packet driver supports SMP and therefore the legacy GRSPW
driver is disabled for SMP builds.
Update #2355
Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
The UT699 requires -mcpu=leon as it does not support the CAS instruction
provided by -mcpu=leon3. It also requires -mfix-ut699 for errata fixes.
UT700 and GR712RC requires the -mfix-ut700 and -mfix-gr712rc flags that
have been recently added to GCC's master and 7-branch.
Remove -msoft-float from the leon3 config to make the more common case
of using the FPU the default.
Update #3057.
This driver was initially intended for APBUART access on GRLIB PCI
peripherals (AMBA-over-PCI). There are already many APBUART drivers
for LEON. Instead of using this one the termios APBUART should work
on AMBA-over-PCI systems with recent changes on LEON3, however that
has not been tested yet.
