* configure.ac: Remove libchip/ide/Makefile, libchip/network/Makefile,
libchip/serial/Makefile, libchip/rtc/Makefile.
* configure.ac: Reflect having moved tests to ../../testsuites.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/check-cpu.m4: Remove.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Make presence of tests/ optional.
* configure.ac: Remove stray comments.
* automake/local.am, automake/host.am: Remove "debug".
* lib/Makefile.am: New (Required by 'make dist').
* lib/ChangeLog: Remove.
* lib/.cvsignore: Cleanup.
* configure.ac: Reflect having added lib/Makefile.am.
* configure.ac: Merge-in lib/libcpu/configure.ac.
Merge-in lib/libbsp/configure.ac.
* configure.ac: Use relative dir to make/${RTEMS_BSP}.cache.
* configure.ac: Merge-in librdbg/configure.ac.
* configure.ac: Merge-in libnetworking/configure.ac.
Merge-in parts of librdbg/configure.ac.
* configure.ac: Merge-in libchip/configure.ac.
Merge-in optman/configure.ac.
* configure.ac: Remove support for profile-variant.
* configure.ac: Remove libmisc.
* configure.ac: Append RTEMS_CPU_MODEL to ac_configure_args.
Resort cache-checking.
* configure.ac: Expand RTEMS_CHECK_BSP_CACHE.
* configure.ac: Append CPU_CFLAGS, CFLAGS_OPTIMIZE_V,
CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY to
ac_configure_args.
* configure.ac: Use test "$RTEMS_BSP_FAMILY" != "bare" to setup
HAS_LIBBSP conditional (Solaris/bash incompatibility fix).
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* configure.ac: Add ada-tests.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* configure.ac: Add BSP_SUBDIRS.
* Makefile.am: Use BSP_SUBDIRS to setup SUBDIRS.
* configure.ac: Remove AC_CONFIG_SUBDIR(wrapup).
Cosmetic cleanups.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Append BARE_CPU_MODEL tp make/@RTEMS_BSP@.cache
creation (Make the bare BSP happy).
* configure.ac: Ditto.
* Makefile.am: Create make/@RTEMS_BSP@.cache.
Handle make/custom/*.cfgs.
Create make/custom/default.cfg.
* configure.ac: Add creation of make/custon/*.cfg.
Create make/${RTEMS_BSP}.cache.
Read make/${RTEMS_BSP}.cache
* acinclude.m4: Cleanups.
* configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of
${srcdir}/exec/.
Further adaptations to autoconf >= 2.50.
* acinclude.m4: New.
* Makefile.am: Remove tar-installation.
Prepend @exec@ to SUBDIRS.
* configure.ac: Switch to AC_CONFIG_SRCDIR([optman]).
Add RTEMS_ENABLE_MULTIPROCESSING.
Add RTEMS_CONFIG_SUBDIR([exec]...).
* configure.ac: Remove librpc.
* configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* configure.ac: Remove lib.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* configure.ac: Modified to reflect addition.
* configure.ac: Add AC_CONFIG_SUBDIRS(optman). Remove
AC_CONFIG_COMMANDS.
* Makefile.am: Use SUBDIRS = @subdirs@, require automake-1.5.
* configure.ac: Replace hst_subdirs with AC_CONFIG_SUBDIRS to make
autoconf-2.52 happy.
* configure.in: Remove.
