Update #4180
Update #4180
Update #3910.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
In a multi-processor system we must broadcast the TLB maintenance operation to
the Inner Shareable domain to ensure that the other processors update their TLB
caches accordingly.
Close #4068.
Closes #4055
Closes #4056
_CPU_Counter_frequency() can be called by the rtems_counter
initialization before arm_gt_clock_initialize() initializes the value
used in _CPU_Counter_frequency().
Closes #3961.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
At least on GICv1 the interrupts 0 up to including 31 are so called
Peripheral Private Interrupts (PPIs). We have to initialize the
priority of the PPIs on secondary processors.
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
This avoids to pull in via printk() the Termios support which pulls in
the file system support. This fixes a spconfig02 test failure.
Update #3838.
This adds support for the GICv3 interrupt controller along with the
redistributor to control SGIs and PPIs which wasn't present in GICv2
implementations. GICv3 implementations only optionally support
memory-mapped GICC interface interaction and require system register
access be implemented, so the GICC interface is accessed only
through system registers.
Close #3789.
Xen will mask the virtual timer before injecting the interrupt to the
guest.
Xen currently only supports the zImage loader for 32 bit guests on ARM
targets.
The small page MMU support reduces the granularity for memory settings
through the MMU from 1MiB sections to 4KiB small pages.
Enable it by default on the realview_pbx_a9_qemu BSP.
- The TI's CortexA7 MP MPIDR register returns 0
Updates #3760
Closes #3760
This fixes the corruption of r3 by the call to
bsp_start_arm_drop_hyp_mode().
Moving the code makes it easier to review changes in start.S.
Close #3773.
This makes it easier to review changes in start.S.
Update #3773.
There are no known ARMv7-M chips with a dual lockstep mode.
Update #3773.
Closes #3762
Use _SMP_Multicast_action() instead.
This driver will be shared with the xilinx-zynqmp BSP.
Update #3682.
Update #3706.
Update #3706.
replace.
searching and sorting.
Update #3706.
The following variants
* GICv1 with Security Extensions,
* GICv2 without Security Extensions, or
* within Secure processor mode
have the ability to assign group 0 or 1 to individual interrupts. Group
0 interrupts can be configured to raise an FIQ exception. This enables
the use of NMIs with respect to RTEMS.
BSPs can enable this feature with the BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
define. Use arm_gic_irq_set_group() to change the group of an
interrupt (default group is 1, if BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0 is
defined).
This makes the @file documentation independent of the actual file name.
Update #3707.
Move device tree copy operation after the mode initialization so that
bsp_fdt_copy() uses the initialization stack and not the stack provided
up by the boot loader.
Update #3456.
Update #3459.
Update #3667.
Close #3674.
Update #3667.
Close #3667.
Remove this superfluous define.
Update #3667.
The boot_card() function does not return.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
