The nocache-memory was set as device memory. It's not necessary to be
that strict. Set it to normal non-cacheable non-shareable memory
instead.
The flash configuration is something very board specific. So move the
file to a board specific location. Beneath that, not all controllers and
configurations need the flash config right at the address 0 of the
flash. For example on the i.MXRT11xx, the config has an offset for some
flash types.
brains GmbH.
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Update #4180
