The build fails when TMS570_USE_HWINIT_STARTUP=1 option is set.
closes #3347
Initial idea has been that check for both, TMS570_SCI_FLR_TX_EMPTY
and TMS570_SCI_FLR_TXRDY is required before console driver parameters
update.
closes #2883.
TMS5704357 ZWT chip.
The extended mechanism for switching input path by separated
alternative registers is already implemented in TMS570
pin multiplexer driver used for TMS570LS31xx
rtems/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
But the code has not been tested on real TMS570LC43xx hardware yet.
The single write to memory or ioport output are mostly
atomic operations already. The proper memory synchronization barrier
should be used around them to guarantee ordering (sync or eieio
on PowerPC for example) but because I have not found settable
portable primitive only compiler barrier is used.
It should be enough on x86 because the externally visible order
should be/is guaranteed to be preserved on x86 architecture.
When GCC option -march is not specifies i386-rtems toolchain
defaults to i386 architecture instruction set. It does not
provide atomic instructions which results in really inefficient
atomic_fetch_or even on UP build.
SMP build is broken with i386 set because libatomic and GCC
generate infinite loop for __atomic_fetch_add_4 used
in rtems_interrupt_lock_acquire
__atomic_fetch_add_4:
push %ebp
mov %esp,%ebp
movl $0x5,0x10(%ebp)
pop %ebp
jmp __atomic_fetch_add_4
The global state of enabled and disabled interrupts has to hold
interrupts really disabled by drivers and system. If the state is
combined with interrupts temporarily disabled because they are
processed at given time then it is impossible to maintain state
by interrupt handlers in drivers.
The use of actual cache line max bytes and minimum required alignment
in architecture but not-BSP dependent code could be problematic
because there exists even ARM instruction set implementations
with 128 byte line length and real maximum can be quite problematic
to say. But actually supported ARM BSPs should be OK with these values.
Use of rtems_cache_get_maximal_line_size() is more descriptive
choice. The min/max data/instruction cache line size is not critical
there, value is used for optimization only to use single operation
for directly following sections.
startup and selftest.
HalCoGen generated files.
The configuration is specific for TMS570LS3137 based HDK.
Pins configuration can be easily changed in
rtems/c/src/lib/libbsp/arm/tms570/hwinit/init_pinmux.c
file.
The list tms570_selftest_par_list in the file
rtems/c/src/lib/libbsp/arm/tms570/hwinit/bspstarthooks-hwinit.c
specifies peripherals which health status is examined
by parity self-test at BSP start-up. It can be easily
modified for other TMS570 family members variants same
as the selection of other tests in bspstarthooks-hwinit.c.
Generated header file ti_herc/reg_spi.h contains complete registers
and fields set for Ti MibSPI peripheral.
Care has to be taken that only TMS570_SPI1, TMS570_SPI3 and TMS570_SPI5
are of this complete multibuffer type. TMS570_SPI2 and TMS570_SPI4
have substantial part of registers removed but else they are compatible.
The symbol can be used by bsp_start_hook_0 when complete
RAM memory is initialization and overwritten during BSP
self-test. The test overwrites even memory used to store
return address / link register and regular resturn from
bsp_start_hook_0 is not possible then.
Tested to work with QEMU provided Intel i82557b network controller emulation.
qemu-system-x86_64 -enable-kvm -kernel $APP_BINARY \
-vga cirrus \
-append "--console=/dev/com1" \
-serial stdio \
-net nic,vlan=1,macaddr=be:be:be:10:00:01,model=i82557b \
-net tap,ifname=tap1,vlan=1,script=no,downscript=no
more available on i386.
This change is required to build RTEMS with classic "--enable-networking"
and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_ATTACH.
Whether the board is restarted after application finish/exit
is controlled by BSP_RESET_BOARD_AT_EXIT configure option.
It has advantage that it is designed as free-running counter
with compare registers and can easily serve for for both
timecounter and tick interrupt.
The BSP support is divided to startup/bspsmp_api.c file where
functions required by SuperCore are defined and BCM2836 hardware
initialization part in startup/bspsmp_init.c.
Separation is done to prevent smpfatal08 test build failure.
processing.
level.
New function arm_cp15_cache_invalidate_level and arm_cp15_cache_clean_level
can be used to maintain single cache level (instruction or data).
Protection by rtems_interrupt_disable() is incompatible with SMP build.
Actual page table entries manipulation function does not need locking
and disabling cache and can be run concurrently even on multiple
CPUs as long as changes do not modify same region. If the function
is called from more threads/CPUs to modify same region with different
mapping options concurrently then there is problem at another level
of virtual address space management and has to be solved by mutex
or other locking at that level.
The change documents meaning of codes and opens
well defined way to use cache type format for cache
examination/debugging outside of arm-cp15.h file.
initialization starts.
The u-boot loader enables the MMU plus the data and instruction caches
in some versions which results in RTEMS boot failure.
Closes #2774.
runtime init if required.
Code works but there is problem how to setup caching for the regions
(arm_cp15_set_translation_table_entries arguments).
If ARMV7_MMU_DATA_READ_WRITE_CACHED is used then CPU
accesses are noncoherent with VideoCore and some
part of image update are not visible until pushed from
cache by other activities. If ARMV7_MMU_DATA_READ_WRITE
is used then access is extremely slow.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
error checking.
The first, mistake in buffer size computation for cache flush
and invalidate has been corrected.
GCC __attribute__( ( aligned( 64 ) ) ) should work and works for local
variables. Code ensures right stack alignment. But attribute has
to be moved to type declaration to ensure that structure size is affected
by attribute. But even this seems to not work reliably for some reason.
May it be, the stack area between frame start and end of local variable buffer
accessed during context switch or some stack prefetch during resturn
such way that some cache lines belonging to buffer are filled to cache.
Extending buffer by one more cache line padding helps there.
In the longer term perspective, buffer should be moved to some static
area or cache aligned dynamic memory allocated. Concurrent calls
to the VideoCore operations and access serialization should be added
too but problem is that some calls are required during workspace and MMU
setup so variant without need of mutex would be required as well.
Framebuffer setup code and other VideoCore calls check more
precisely for errors and do not proceed forward with incorrect
data now.
Mudit Jain'a tree.
based approach.
Using conditional branches to find bits is extremely inefficient
and for asynchronous delivery of different interrupt sources
lead to total confusion of branch prediction unit.
exception table.
Exception table setup is processed by common CPU architecture support.
For ARM architecture, it can be found in the file
rtems/c/src/lib/libbsp/arm/shared/start/start.S
and ends by bsp_vector_table_copy_done label.
The actual tabel content can be found at
bsp_start_vector_table_begin
For ARMv7-A and even other variant with hypervisor mode support,
it is even not necessary to copy table to address 0 at all
because CP15 register can be used to specify alternative
table start address
arm_cp15_set_vector_base_address(&)bsp_start_vector_table_begin;
ARMv7-M have register to set exception table base as well.
of character Tx.
The rtems_monitor_task() setups/updates termios attributes
of the opened TTY and if there is ongoing some other output
it leads to the stuck.
It would be better to use some termios API function which
would call drainOutput() in rtems/cpukit/libcsupport/src/termios.c.
But functionality is not accessible outside of core termios
implementation.
The loop waiting for last character to be sent has to be there anyway
because hardware does not provide Tx machine/shift register empty
interrupt.
Memory content changes caused by relocation has to be
propagated to memory/cache level which is used/snooped
during instruction cache fill.
Closes #2438
later to RO.
Enable even the first megabyte of SDRAM to be cache-able after
problems with stale cache content has been resolved by previous commit.
Because major part of application usually fits to the first
megabyte this speedups test dhrystone application by factor 40.
levels.
This fix strange behavior where some stale content has been
stored in level 2 cache before RTEMS has been start from U-boot
which has reappeared after MMU enable and shadow vector
table at start of SDRAM.
architecture variants now.
Next cache operations should work on most of cores now
rtems_cache_flush_entire_data()
rtems_cache_invalidate_entire_data()
rtems_cache_invalidate_entire_instruction()
Instruction cache invalidate works on the first level for now only.
Data cacache operations are extended to ensure flush/invalidate
on all cache levels.
The CP15 arm_cp15_data_cache_clean_all_levels() function extended
to continue through unified levels too (ctype = 4).
Disabling MMU requires complex cache flushing and invalidation
operations. There is almost no way how to do that right
on SMP system without stopping all other CPUs. On the other hand,
there is documented sequence of operations which should be used
according to ARM manual and it guarantees even distribution
of maintenance operations to other cores for last generation
of Cortex-A cores with multiprocessor extension.
This change could require addition of appropriate entry
to arm_cp15_start_mmu_config_table for some BSPs to ensure
that MMU table stays accessible after MMU is enabled
.begin = (uint32_t) bsp_translation_table_base,
.end = (uint32_t) bsp_translation_table_base + 0x4000,
.flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
Remove workarounds.
The basic data and instruction rage functions should be compatible
for all ARMv4,5,6,7 functions. On the other hand, some functions
are not portable, for example arm_cp15_data_cache_test_and_clean()
and arm_cp15_data_cache_invalidate() for all versions and there
has to be specialized version for newer cores.
arm_cache_l1_properties_for_level uses CCSIDR which is not present
on older chips.
Actual version is only experimental, needs more changes
and problem has been found on RPi1 with dlopen so there seems
to be real problem.
Synchronize each cluster of sections of the same type separately
to support even cases where text and data are allocated from different
areas (for example due allocation from different MPU protection regions).
rtems_cache_instruction_sync_after_code_change is called even to data
sections. Propagation of data only changes should not require cache
maintenance operation on sane SMP mutithread capable systems if barrier
instruction is added but be on safe side even for case where self
modifying code uses data sections initial values etc.
BSPs.
The original ARM architecture wide cache_.h is changed to dummy version
for targets not implementing/enablig cache at all.
The ARM targets equipped by cache should include
appropriate implementation.
Next options are available for now
c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
basic ARM cache integrated on the CPU core directly
which requires only CP15 oparations
c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
support for case where ARM L2C-310 cache controller
is used. It is accessible as mmaped peripheral.
c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
Cortex-M specific cache support
and maximal alignment.
There is need for unambiguous named and defined cache function
which should be called when code is updated, loaded
or is self-modifying.
There should be function to obtain maximal cache line length
as well. This function can and should be used for allocations
which can be used for data and or code and ensures that
there are no partial cache lines overlaps on start and
end of allocated region.
The arm_cp15_data_cache_clean_and_invalidate leads to hang on RPi2,
clean by individual lines works on RPi1 and RPi2.
Some/many Cortex-A cores have data cache line length 64 bytes and maximum
value has to be used for system structures alignment.
