path: root/spec/build/bsps/m68k/uC5282/bspuc5282.yml (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* spec/bsps: Do not install tm27.hChris Johns2022-08-221-1/+0
| | | | Updates #4705
* build: Use common objects item for get memorySebastian Huber2021-11-301-1/+2
* spec: Remove RTEMS_NETWORKING optionsVijay Kumar Banerjee2021-04-071-2/+0
| | | | Update #3850
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* build: Alternative build system based on wafSebastian Huber2020-09-141-0/+55
Update #3818.
