brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Updates #4705
OPTIMIZATION_FLAGS must be defined before /build/bsp/bspopts is processed.
Update #4670.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
Add rtems_interrupt_entry_remove(). Split up irq-generic.c into several files.
In particular, place all functions which use dynamic memory into their own
file.
Add optional macros to let the BSP customize the vector installation after
installing the first entry and the vector removal before removing the last
entry:
* bsp_interrupt_vector_install()
* bsp_interrupt_vector_remove()
Use these new customization options in the m68k/genmcf548x BSP so re-use the
generic interrupt controller support.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
Add rtems_interrupt_vector_disable().
Update #3269.
Update #3269.
Update #3269.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Update #3850
Update #4267.
Update #4267.
Use the Python sorted() function to sort the "source" lists.
Update #3818.
