* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | build: Add cppflags, cflags, cxxflags to groups | Sebastian Huber | 2022-07-04 | 1 | -0/+3 |
| | | | | | | | Propagate the group defined cppflags, cflags, and cxxflags from parent groups to child items through the build item context. Update #4670. | ||||
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 1 | -0/+2 |
* | bsps/irq: Add rtems_interrupt_entry_install() | Sebastian Huber | 2021-07-26 | 1 | -0/+2 |
| | | | | | | | | | | | | | | | | | | | Add rtems_interrupt_entry_remove(). Split up irq-generic.c into several files. In particular, place all functions which use dynamic memory into their own file. Add optional macros to let the BSP customize the vector installation after installing the first entry and the vector removal before removing the last entry: * bsp_interrupt_vector_install() * bsp_interrupt_vector_remove() Use these new customization options in the m68k/genmcf548x BSP so re-use the generic interrupt controller support. Update #3269. | ||||
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 1 | -2/+0 |
| | | | | Update #3850 | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+38 |
Update #3818. |
