* | bsps/arm: Use shared empty bsp_start_hook_0() | Sebastian Huber | 2024-01-15 | 1 | -0/+1 |
| | | | | Update #4982. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec/bsps: Do not install tm27.h | Chris Johns | 2022-08-22 | 1 | -1/+0 |
| | | | | Updates #4705 | ||||
* | bsps: Default to CPU counter benchmark timer | Sebastian Huber | 2022-01-15 | 1 | -1/+1 |
| | | | | | | Most BSPs which used the stubbed benachmark timer provide a CPU counter. All BSPs provide at least a stub CPU counter. Simply use the benchmark timer implementation using the CPU counter. | ||||
* | bsps/arm: Add missing Cache Manager source file | Sebastian Huber | 2021-12-13 | 1 | -0/+1 |
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 1 | -1/+2 |
* | bsps/gicv2: Allow BSPs to define IRQ attributes | Kinsey Moore | 2021-09-21 | 1 | -0/+1 |
| | | | | | | | ARM's GICv2 is configurable and its attributes vary between implementations including omission of specific interrupts. This allows BSPs to accomodate those varying implementations with customized attribute sets. | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 1 | -2/+2 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | bsps: Use header file for GIC architecture support | Sebastian Huber | 2020-12-23 | 1 | -1/+0 |
| | | | | | | This avoids a function call overhead in the interrupt dispatching. Update #4202. | ||||
* | bsps/arm: Unify ARM Generic Timer options | Sebastian Huber | 2020-12-10 | 1 | -1/+1 |
* | bsps: Move ARM GICv2 driver to bsps/shared | Kinsey Moore | 2020-12-02 | 1 | -1/+2 |
| | | | | | This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64 code. | ||||
* | bsps: Break out AArch32 portions of GPT driver | Kinsey Moore | 2020-10-05 | 1 | -1/+5 |
| | | | | | | This breaks AArch32-specific portions of the ARM GPT driver into their own file so that the generic code can be moved for reuse by other architectures. | ||||
* | Move ARM PL011 UART driver | Kinsey Moore | 2020-10-05 | 1 | -1/+0 |
| | | | | This UART driver is now needed for BSPs other than ARM. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+78 |
Update #3818. |
