Update #4982.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Use yaml.dump(data, default_flow_style=False, allow_unicode=True) with a
custom representer for integer default values to format all build items.
Updates #4705
Most BSPs which used the stubbed benachmark timer provide a CPU counter.
All BSPs provide at least a stub CPU counter. Simply use the benchmark
timer implementation using the CPU counter.
ARM's GICv2 is configurable and its attributes vary between
implementations including omission of specific interrupts. This allows
BSPs to accomodate those varying implementations with customized
attribute sets.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Update #4267.
Use the Python sorted() function to sort the "source" lists.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Update #4202.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
Update #3818.
