QEMU is known to fail certain tests intermittently due to clock tick
delivery issues. This defines those tests as intermittent for BSPs
intended to run on QEMU alone.
Updates #4922
Updates #4072
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
The spconfig01 and spmisc01 tests were disabled for all AArch64 BSPs due
to a toolchain issue preventing them from compiling correctly. The
binutils version that contains the fix has been released and integrated
into RSB such that these two tests now build and operate correctly.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
This enables several testsuites that were initially disabled during
development.
Closes #4179.
The spintrcritical03-05 and psx12 tests are known to fail on Qemu when
the host system is heavily loaded. A single run of Qemu per core
during a testsuite run tends to yield positive results, but any
additional load on a system will result in test failures.
This patch also applies the correct expected test state for intermittent
failures so that those tests will still build.
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
