* intr_NOTIMES.t: Real version submitted.
* BSP_TIMES, wksheets.texi: Updated to reflect ARM times
reported by Jay Monkman <jmonkman@adventnetworks.com>. These
times are subject to change as he tunes the ARM port and their BSP.
* Makefile.am: Added arm subdirectory.
* intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* .cvsignore: Corrected some errors.
* timeMVME136.t, timedata.t: Replaced XXX's with real info.
* callconf.t: Added some markups for fonts and clarified
some places.
* .cvsignore: Corrected by tailoring for the ARM.
* .cvsignore: New file.
* BSP_TIMES, ChangeLog, Makefile.am, arm.texi, bsp.t, callconv.t,
cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t,
preface.texi, stamp-vti, timeBSP.t, timing.texi, version.texi,
wksheets.texi: New files as ARM supplement initial version added.
CPUDIR=/opt/rtems/powerpc-rtems/include
cd $BSPDIR
find . -name "*.h" | while read f
do
if [ -r ${CPUDIR}/${f} ] ; then
echo Conflict on ${f}
fi
done
* intr_NOTIMES.t: Per PR70 incorporate the posting by
Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* mips: New supplement.
* bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t,
fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi,
preface.texi, stamp-vti, timeBSP.t, version.texi: New files.
* supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
This patch changes the installation directory of the supplements to
supplements/<cpu>.
This allows browsing the html files inside of the source tree,
because after having applied this patch, the structure of the html
installation directory hierarchy is the same as the directory
structure of the source tree.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
viewer can have section headings.
figures included.
chapters.
as possible.
