Replace the separate user extension iterations with a single iteration
function. This reduces code size and improves maintainability since the
iteration logic is only in one function. The runtime overhead is
insignificant.
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/extensioncreate.c,
sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h,
score/src/userextthreaddelete.c, score/src/userext.c,
score/src/userextthreadcreate.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextaddset.c,
score/src/userextthreadrestart.c: Documentation. The types
User_extensions_routine and rtems_extension are now deprecated.
Removed unused types User_extensions_thread_post_switch_extension and
rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set()
in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in
_User_extensions_Add_set_with_table().
* score/src/userextaddapiset.c: Removed file.
* score/Makefile.am: Update.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c,
sapi/Makefile.am, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/include/rtems/score/userext.h, score/src/chain.c,
score/src/userext.c: Switch to newlib reentrancy extension being
installed in the initial set instead of using rtems_extension_create.
While implementing this, noticed that user extensions and chain code
had multiple functions in a single file which is not desirable in the
SuperCore and API portions of RTEMS, so split these into multiple
files with one function per file. Also noticed that some of user
extension code was inlined for no particular reason so moved that to
C bodies. Split executive shutdown from initialization since not
every application shuts down. Moved __fini call to executive shutdown
to be more symmetrical with where it is called at startup.
* sapi/src/exshutdown.c, score/src/chainappend.c,
score/src/chainextract.c, score/src/chainget.c,
score/src/chaininsert.c, score/src/userextaddapiset.c,
score/src/userextaddset.c, score/src/userextremoveset.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c: New
files.
* score/inline/rtems/score/userext.inl: Removed.
