The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
Remove superfluous header file includes from various files.
Move implementation specific parts of scheduler.h and scheduler.inl into
new header file schedulerimpl.h. The scheduler.h contains now only the
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* sapi/include/confdefs.h, score/Makefile.am,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/threadclearstate.c, score/src/threadclose.c,
score/src/threadinitialize.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetpriority.c,
score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the
pluggable scheduler interface. Its configuration made a table
of available schedulers and set a pointer to one of the.
This was heavy handed since you can only use one scheduler
in an application. This configuration mechanism resulted in a
scheduler pointer being passed around when you could put all
scheduler configuration in an initialized structure.
* libmisc/capture/capture.c, posix/src/keyfreememory.c,
posix/src/pthread.c, score/include/rtems/score/wkspace.h,
score/src/objectextendinformation.c,
score/src/objectnamespaceremove.c, score/src/objectsetname.c,
score/src/wkspace.c: Many places were checking for a NULL pointer
before calling _Workspace_Free. By moving the check into
_Workspace_Free, we eliminate a number of conditional paths and make
it harder to return a NULL pointer.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* score/src/threadchangepriority.c: Just in case the transient
state was set when we entered, ensure that it is still set when
we exit.
* score/src/threadclose.c: When a thread is being deleted, it should
go into the dormant state -- not the transient state.
* itron/include/rtems/itron/task.h, itron/src/cre_tsk.c,
posix/src/pthreadcreate.c, rtems/src/taskcreate.c,
rtems/src/taskdelete.c, rtems/src/timerserver.c,
score/src/threadinitialize.c: Switch task create and delete
operations to using API Allocator Mutex. This moves almost all uses
of the RTEMS Workspace from dispatching disabled to mutex protected
which should improve deterministic behavior. The implementation was
carefully done to allow task create and delete extensions to invoke
more services. In particular, a task delete extension should be able
to do mutex and file operations.
PR 533/bsps
* startup/linkcmds: Update linkcmds for gcc 3.3.2.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/Makefile.am, include/rtems/score/coremsg.h,
include/rtems/score/coremutex.h, include/rtems/score/coresem.h,
include/rtems/score/object.h, include/rtems/score/threadq.h,
inline/rtems/score/object.inl, inline/rtems/score/thread.inl,
macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c,
src/coremutex.c, src/coresem.c, src/mpci.c,
src/objectcomparenameraw.c, src/objectextendinformation.c,
src/objectinitializeinformation.c, src/objectnametoid.c,
src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c,
src/threadqextractwithproxy.c: Modified as part of above.
* include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New
files.
split into one function per file, this will decrease the size of executables.
