The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
Updates #3053.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Update #2556.
Changed for consistency with other scheduler operations.
Update #2556.
Previously, the _Thread_Heir was updated unconditionally in case a new
heir was determined. The _Thread_Dispatch_necessary was only updated in
case the executing thread was preemptible or an internal thread was
unblocked. Change this to update the _Thread_Heir and
_Thread_Dispatch_necessary only in case the currently selected heir
thread is preemptible or a dispatch is forced. Move the schedule
decision into the change priority operation and use the schedule
operation only in rtems_task_mode() in case preemption is enabled or an
ASR dispatch is necessary. This is a behaviour change. Previously, the
RTEMS_NO_PREEMPT also prevented signal delivery in certain cases (not
always). Now, signal delivery is no longer influenced by
RTEMS_NO_PREEMPT. Since the currently selected heir thread is used to
determine if a new heir is chosen, non-preemptible heir threads
currently not executing now prevent a new heir. This may have an
application impact, see change test tm04. Document this change in sp04.
Update #2273.
Return a thread in need for help for the following scheduler operations
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
The _Scheduler_Yield() was called by the executing thread with thread
dispatching disabled and interrupts enabled. The rtems_task_suspend()
is explicitly allowed in ISRs:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Interrupt-Manager-Directives-Allowed-from-an-ISR.html#Interrupt-Manager-Directives-Allowed-from-an-ISR
Unlike the other scheduler operations the locking was performed inside
the operation. This lead to the following race condition. Suppose a
ISR suspends the executing thread right before the yield scheduler
operation. Now the executing thread is not longer in the set of ready
threads. The typical scheduler operations did not check the thread
state and will now extract the thread again and enqueue it. This
corrupted data structures.
Add _Thread_Yield() and do the scheduler yield operation with interrupts
disabled. This has a negligible effect on the interrupt latency.
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Add and use _Scheduler_priority_Get_scheduler_info().
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of schedulerpriority.h and
schedulerpriority.inl into new header file schedulerpriorityimpl.h. The
schedulerpriority.h contains now only the application visible API.
Add missing includes. Remove superfluous includes.
Move declaration of _Priority_Bit_map to prioritybitmap.inl since this
variable is used only here.
Remove second declaration of _Priority_Major_bit_map.
The yielding thread of the yield operation is now specified by a
parameter. The tick operation may be performed for each executing
thread in a SMP configuration.
* sapi/include/confdefs.h, score/Makefile.am,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/threadclearstate.c, score/src/threadclose.c,
score/src/threadinitialize.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetpriority.c,
score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the
pluggable scheduler interface. Its configuration made a table
of available schedulers and set a pointer to one of the.
This was heavy handed since you can only use one scheduler
in an application. This configuration mechanism resulted in a
scheduler pointer being passed around when you could put all
scheduler configuration in an initialized structure.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
* sapi/include/confdefs.h, score/include/rtems/score/scheduler.h,
score/src/schedulerpriorityyield.c: Added attribute unused. Renamed
types and fields to follow the Score naming conventions.
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
