* | score/src/[n-s]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | Return status code for _Scheduler_Set_affinity() | Sebastian Huber | 2021-04-27 | 1 | -1/+1 |
| | | | | | This avoids having conditional statements to get the API-specific status code. | ||||
* | score: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -2/+3 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -2/+2 |
* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 1 | -1/+1 |
| | | | | Update #3706 | ||||
* | score: Add scheduler node to set affinity op | Sebastian Huber | 2017-07-07 | 1 | -0/+2 |
| | | | | Update #3059. | ||||
* | score: Use processor mask for set affinity | Sebastian Huber | 2017-07-07 | 1 | -4/+2 |
* | score: Task get/set affinity | Sebastian Huber | 2014-04-15 | 1 | -5/+6 |
| | | | | | Make rtems_task_get_affinity() and rtems_task_set_affinity() available on non-SMP configurations. Allow larger CPU sets. | ||||
* | score: Static scheduler configuration | Sebastian Huber | 2014-04-15 | 1 | -4/+4 |
| | | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP. | ||||
* | score: Add scheduler control to scheduler ops | Sebastian Huber | 2014-04-04 | 1 | -3/+7 |
| | | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling. | ||||
* | score: score: Add get/set affinity to Scheduler Framework. | Jennifer Averett | 2014-04-03 | 1 | -0/+32 |
