brains GmbH.
The uniprocessor schedulers do not support systems with more than more
processors. So they rivially support thread pinning and thus the
SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED cannot happen.
Add a second default implementation for SMP schedulers which do not
support thread pinning.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be
in line with the API level rtems_scheduler_get_processor_maximum().
Update #3732.
Add support to temporarily pin a thread to its current processor. This
may be used to access per-processor data structures in critical sections
with enabled thread dispatching, e.g. a pinned thread is allowed to
block.
Update #3508.
