brains GmbH.
Remove URL in copyright notice.
Update #3053.
Split up rbtreenext.c since only _RBTree_Minimum() is used by the operating
system core services (thread queues and the EDF scheduler).
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
Use the BSD <sys/tree.h> implementation since it is faster, more
flexible and uses less storage. See https://github.com/sebhub/rb-bench.
The user of the red-black tree container must now ensure that at most
one thread at once can access an instance.
Move implementation specific parts of rbtree.h and rbtree.inl into new
header file rbtreeimpl.h. The rbtree.h contains now only the
application visible API.
The implementation of RBTree_Next was using an awkward construction to detect
and avoid accessing the false root of the red-black tree. To deal with the
false root, RBTree_Next was comparing node parents with the control node.
Instead the false root can be detected by checking if the grandparent of a
node exists; the grandparent of the tree's true root is NULL by definition
so the root of the tree is found while walking up the tree by checking for
the non-existence of a grandparent.
This change propagates into the predecessor/successor and iterate functions.
New functions
o _RBTree_Next_unprotected(),
o _RBTree_Next(),
o _RBTree_Successor_unprotected(),
o _RBTree_Predecessor_unprotected(),
o rtems_rbtree_successor_unprotected(), and
o rtems_rbtree_predecessor_unprotected().
Change prototype of
o _RBTree_Successor(),
o _RBTree_Predecessor(),
o rtems_rbtree_successor(), and
o rtems_rbtree_predecessor().
