* | score/rbtree: Delete protected operations | Sebastian Huber | 2013-11-21 | 1 | -37/+0 |
| | | | | | The user of the red-black tree container must now ensure that at most one thread at once can access an instance. | ||||
* | score: Create rbtree implementation header | Sebastian Huber | 2013-07-23 | 1 | -3/+1 |
| | | | | | | Move implementation specific parts of rbtree.h and rbtree.inl into new header file rbtreeimpl.h. The rbtree.h contains now only the application visible API. | ||||
* | score misc: Score misc: Clean up Doxygen #11 (GCI 2012) | Daniel Georgiev | 2012-12-01 | 1 | -18/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013204 | ||||
* | 2010-07-28 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2011-04-04 | 1 | -0/+52 |
PR 1641/cpukit * sapi/Makefile.am, sapi/preinstall.am, score/Makefile.am, score/preinstall.am: Add Red Black Tree data structure to score. * sapi/include/rtems/rbtree.h, sapi/inline/rtems/rbtree.inl, score/include/rtems/score/rbtree.h, score/inline/rtems/score/rbtree.inl, score/src/rbtree.c, score/src/rbtreeextract.c, score/src/rbtreefind.c, score/src/rbtreefindheader.c, score/src/rbtreeget.c, score/src/rbtreeinsert.c, score/src/rbtreepeek.c: New files. |
