* | score: Improve C/C++ standard compatibility | Sebastian Huber | 2024-04-09 | 1 | -1/+1 |
| | | | | | | The processor mask implementation uses flsl() from <strings.h> which is only BSD visible. Move the implementation to a separate header file to hide it from the API level. This fixes build errors with GCC 14. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | score/src/[n-s]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | score: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -2/+4 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 1 | -1/+1 |
| | | | | Update #3706 | ||||
* | score: Move processor affinity to Thread_Control | Sebastian Huber | 2017-07-07 | 1 | -0/+2 |
| | | | | Update #3059. | ||||
* | score: Add processor mask to/from cpu_set_t | Sebastian Huber | 2017-07-06 | 1 | -0/+75 |
Update #3059. |
